Would it be 17cm mid to 307 front doors
08.05.2020 16:49 # 1
tayfur
friends, I think the sound system for the car, there is a mid that I set for the doors in this system, but 17cm.
I think the front doors of our 307s are 16cm. http: //www.pio neer.eu/tr/products/null/null/201/TS-E170Ci/index.html "target =" _ blank "rel =" nofollow "> http://www.pioneer .eu / en / products / null / null / 201 / TS-E170Ci / index.html
the system that I think has not received anything for the system right now,
main unit- & nbsp ; & nbsp; pioneer 9350sd or & nbsp; LG lac-m9600r
front mid- & nbsp; & nbsp; pioneer ts-e170ci
I leave the backs blank for now.
subwoofer- in my hand orion 30 cm & nbsp; yes
amp- & nbsp; & nbsp; jbl gto-535.5 I think it would be enough 5 channels
tayfur 2012-05-27 20:56:38
08.05.2020 16:49 # 2
oguzhan29
I think it is enough for you to buy comp on the back doors.
08.05.2020 16:49 # 3
toGah
No need to put it in the back, take a good mid team instead of that budget 17cm
30cm behind the back and 4 channel amps will solve your work.
08.05.2020 16:49 # 4
sercinho
It would be 17 cm, no problem, I would recommend buying a good component.
08.05.2020 16:49 # 5
tayfur
I listened to the pioneer ts-e170ci media mark, which I set as components, it was pretty good, what better would you suggest,
08.05.2020 16:49 # 6
toGah
Do not think that the comps you listen to will give the same sound when connected in your vehicle, all of them change the sound from the converter to the processor to the amplifier. have the installation installed, install the comps, see if you don't like it, have another
