Works like a Peugeot 307 tractor
08.05.2020 16:34 # 1
neo206
Have a nice day. 3 days ago, I came from a 500 km trip and parked my Peugeot 307 Xr gasoline manual gearbox in front of my house. even louder than your voice. It was as if the pistons were hitting something. I even thought that a cat might have gotten inside the engine. In the afternoon, I waited for the air to warm up a bit, the winner was 7-8 streams. I went and started the engine again, the same horrible sound. I pulled the dipstick and checked its oil, checked the water container, everything looks normal. I wonder what is the reason. My car is at 70.00 km. Last year, I changed the timing belt because it was broken. What should I do now?
08.05.2020 16:34 # 2
peugeotefe
Was there antifreeze in the vehicle and what is the engine volume of the vehicle?
08.05.2020 16:34 # 3
neo206
We have antifreeze ... 1.6 engine gasoline ....
08.05.2020 16:34 # 4
peugeotefe
When you give gas, you say, 3 thousand cycles do not pass and it works loudly. Is it true that there is engine oil?
How does a sound come from?
08.05.2020 16:34 # 5
neo206
I pulled the dipstick and looked at it .. Normal ... Tar tar tar ....... plug and play ..... as if it was pouring iron on the anvil that had taken someone attractive to you, it was constantly scary and loud.
08.05.2020 16:34 # 6
peugeotefe
There may be a bed sound, how many thousand of vehicles do you have a decrease in the sound when you give gas?
08.05.2020 16:34 # 7
neo206
At 70.000 km .... I came to Istanbul from Ankara, there was no problem. I did not run for 3 days then it snowed on it .... I ran it where I parked ...
08.05.2020 16:34 # 8
neo206
The sound comes out constantly. The sound comes at the same rate whether I give it or not. All neighbors are disturbed by the sound ... So the sound is so loud ...
08.05.2020 16:34 # 9
peugeotefe
There is no km in the vehicle, it is a little difficult to have a bearing noise.
08.05.2020 16:34 # 10
If I was in questions like this, I shot a video as the first job. I was wondering how something happened.
koliva 2012-02-02 07:34:36
08.05.2020 16:34 # 11
dukenukem82
Look at the coil, I think there's a problem with the ignition. If you give gas, it doesn't stop, it stops, sings like crazy, even the engine light turns on. dukenukem82 2012-02-02 09:00:43
08.05.2020 16:34 # 12
neo206
Anyway, I took it to the mechanic today. The fly gear was broken and they repaired it. It has been done for now .. Thanks
