Works like a bedfort truck?
08.05.2020 16:17 # 1
There is nobody who does not know how bedfort will work as if he is going to stop & nbsp;
What could be the reason when he was idling from time to time in my vehicle?
08.05.2020 16:17 # 2
alisuat
can be a coil.
08.05.2020 16:17 # 3
coil?
08.05.2020 16:17 # 4
Does it sound like & nbsp; `` dzztttttt ''? & nbsp; "Don't & nbsp; Badford sound is coming. Does your idle indicator fluctuate?
08.05.2020 16:17 # 5
There is little ripple in idle but it does not increase, it decreases and rises Idle engine has come to my mind, but I do not think it will be from it.
08.05.2020 16:17 # 6
I have a similar problem. I will replace my idle valve soon.
08.05.2020 16:17 # 7
trigger
if i turn on the air conditioner right away i can
08.05.2020 16:17 # 8
cerci07
[QUOTE = HuseyinTurk] idle fluctuation is very low but does not increase decreases and rises idle engine came to my mind, but I do not think it will happen from it. [/ QUOTE]
Where can you describe the 1.4 idle engine?
08.05.2020 16:17 # 9
Platinium
Coil cannot be a vehicle. There may be a problem with diesel injectors. Is there a blockage or a different fuel? & Nbsp;
08.05.2020 16:17 # 10
[QUOTE = cerci07] [QUOTE = HuseyinTurk] There is little fluctuation in idle, but it does not increase, it decreases and rises. Idle engine came to my mind, but I don't think it will be from it. [/ QUOTE]
1.4 Can you describe the idle engine? ]
take the engine in front of it. It stays on the left side, looking forward, two wires come out from it, the air enters under the filter box, I think that piece is on the left of the oil dipstick
08.05.2020 16:17 # 11
[QUOTE = Platinium] Coil cannot be a vehicle There may be a problem with diesel injectors. Is there a blockage or a different fuel? & Nbsp; [/ QUOTE]
I guess it is related to the injector, but the interesting thing is that it does a thousandth, and when I stop it and start it again, sometimes it doesn't.
08.05.2020 16:17 # 12
"Grin" [QUOTE = Alicangulpinar] & nbsp; also sounds like `` dzztttttt ''? & nbsp; "Don't & nbsp; When I say Badford, I hear that sound directly. Does your idle fluctuate? [/ QUOTE]
"Embarrassed"
08.05.2020 16:17 # 13
tayfundoner
Due to fuel, it can run on poor quality fuel, then stops, idle drops, if you do not press the gas, it just happened to me: D
08.05.2020 16:17 # 14
deniz_206
Huseyin has the same problem with me, my brother, I asked a couple of places, they said that the idle engine was defective, especially when it was first started in the morning, the tachometer falls and rises as if it would stop.
08.05.2020 16:17 # 15
[QUOTE = afaruk307] "Grin" [QUOTE = Alicangulpinar] & nbsp; also sounds like `` dzztttttt '' ? & nbsp; "Laughs" & nbsp; When I say Badford, I hear that sound directly. Does your idle fluctuate? [/ QUOTE]
"Embarrassed"
bzc trucks usually make dızzzttt sound :)
08.05.2020 16:17 # 16
[QUOTE = deniz_206] hüseyin has the same problem with me, brother I asked a few places they said the idle engine was defective, especially when it was first started in the morning, the tachometer falls and rises as if it would stop.
[/ QUOTE] & nbsp;
is not continuous, sometimes it does not matter when it comes to me at first start, sometimes it does not matter, so it blows on its head. >
08.05.2020 16:17 # 17
Huseyin, I do not know exactly, but if you increase the idle of the vehicle, I think if it works for a while, I think it will pass that stage & nbsp;
so it will not connect in bedford :)
08.05.2020 16:17 # 18
emin15
If you think your vehicle is 307 1.4 hdi, the comments are usually made on gasoline engine
08.05.2020 16:17 # 19
yes my car is diesel but we are open to any comments :)
