Works Like 207 Gasoline Diesel (Video)
08.05.2020 19:12 # 1
residents2000
The vehicle sometimes does as in the video. I do not understand if the valves are bent or if the valve is hitting but this situation will make my head slow. I am waiting for the comments of knowledgeable friends. When I do this, the car does not eat gas, it falls from traction, it wets the exhaust floor, it throws out the rain.
[TUBE] zkij5c3hgck [/ TUBE]
[TUBE] xo12nmjox4 the [/ TUBE]
Buddha exhaust
[TUBE] gmzzyiıuna I [/ TUBE]
Did we burn the gasket :(
residents2000 2015-04-03 00:28:45
08.05.2020 19:12 # 2
E.B
very strange situation, the first time I met, a person who has come to the fore will be interpreted
I'm following..
08.05.2020 19:12 # 3
Eric Cartman
The first thing that comes to my mind is that the gasket burns and water enters the combustion chamber. The piston, which is leaking because of the pressure of the water, cannot ignite and the engine has difficulty and sounds like three cylinders are working.
my guess is in this direction, but whatever the problem is, do not start your vehicle until the engine is started. The main problem is understood when the engine is turned on.
08.05.2020 19:12 # 4
Efe-Pojo
what's the problem
08.05.2020 19:12 # 5
TUNAYCAN
Due to the sibob setting, the brother and sister have changed their belt, if they have changed, the master may have worn the synthesis, but if you did not do anything, if you hit the car, you may have jumped to the sentence, so look for trouble in your automatic glory belts 05545485711
