works in the morning for 3 starters
08.05.2020 14:57 # 1
serFBdar
when the car is cold, it does not start immediately. But if I want to turn it off and start it again after running, it works right away. The car is vibrating especially when it is cold, it gets relatively warm when it gets hot and passes to the gas. (My car is 1998 model 306 xn)
08.05.2020 14:57 # 2
serFBdar
the entire ignition system has been overhauled. spark plugs and cables, air filter.vs, etc.
08.05.2020 14:57 # 3
selfat8
Have it done to computer?
08.05.2020 14:57 # 4
GokhaN
did you look at the battery
08.05.2020 14:57 # 5
voodoo
may have a battery problem ......
08.05.2020 14:57 # 6
serFBdar
battery zero, computer clean. There are no masters in the market ....... we are getting crazy.
08.05.2020 14:57 # 7
Haksen016
There may be a problem with the gas pump. After the vehicle is started, it turns the gas pump into mind after it is started and the second start.
08.05.2020 14:57 # 8
Did you try to make a mars after the ignition hurts and the pressure of the gas pump stops?
08.05.2020 14:57 # 9
Haksen016
cecoli, friend's problem yes, probably, we need to test whether the gas pump system is working.
08.05.2020 14:57 # 10
albaywolf
When it is cold, the tremor event disappears when I get into the gas, is this an important problem? Is it worth it to pay and fix? After all, I use LPG and it does not cause any problem in gas.
08.05.2020 14:57 # 11
[QUOTE = albaywolf] Is this tremendous problem when the tremor is getting cold when I switch to gas? Is it worth it to pay and fix? After all, I use LPG and it does not cause any problem in gas. [/ QUOTE]
I think we need to determine where this problem is from and do whatever it takes. mazallah because we are short, the heat does not freeze into the event after the trimming ...
the cecol 2010-11-21 23:09:00
08.05.2020 14:57 # 12
Egeli
my vehicle also has the same problem 206 automatic gear, the car is running in 3 starts, if I do not hold the throttle, it turns back to normal in the third stop flashing indicators back and forth, it turns back to normal at 3rd, there is no problem after working, the first starter is troubled after it, do you think the problem is if you know where to find help I would.
08.05.2020 14:57 # 13
Egeli
the carburetor you call a gas pump friends
08.05.2020 14:57 # 14
kasirga85
friends, our partner (1,9 d) had a problem not working in the morning until a few months ago, we went to the service, they said that the spark plugs will change, we changed it, now it is still difficult to start in the morning in one starter.
