Works in the 3rd press in the morning
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 14:52 # 1
serkan.ist
At 406 2000 ST 110.000KM. Sequential system with LPG. It runs late on first run. As the running time increases, it becomes harder to operate. For example, if I do not work for 3 days 4.-5. works in running. It takes 2-3 in the morning. It doesn't matter whether you press the gas or not. It does not matter whether to open or close the quota.
When working, naturally, there is a smell of raw gasoline. Once working, there is no problem. continues to work normally.
Could it be injection grouting? Or what else can cause. Service says one by one. Anyone experiencing similar problems?
08.05.2020 14:52 # 2
tazmaniac
I am a 206 quiksilver user, I bought the car with gasoline, I had the sequential lpg. I think it might be a problem in your lpgd system, but it may be the same problem when running on gasoline, I think it will be the same. once he did not click ... I guess it is more comfortable working because he does not put the mechanical starter on the load while the foot is in the clutch
