Works at 3 in the morning
08.05.2020 14:18 # 1
serFBdar
MY VEHICLE 1998 306 XN: IN THE MORNING OR WAITING FOR 1, 2 HOURS OF WAITING, THE CAR WORKS AT THREE STARTERS. WHAT CAN IT CAUSE? I CHANGED THE PETROL FILTER. NO PROBLEMS IN WORK AFTER HEAT. I EXPECT YOUR HELP ABOUT THIS. MY SO-CALLED MASTER IS SAYING THINGS I CAN TELL. I DON'T TRUST IT FOR IT NOW IT DOES EVERYTHING FOR MONEY. I CAN GET THE BEST IN A MASTER ADVICE. MY CAR IS LPG. let's 2010-07-07 18:21:02
08.05.2020 14:18 # 2
Huseyin
I would like to tell you a short solution that you can do in your LPG vehicle without suggesting a good master for my brother from Izmit. ..If you wrote the brand of the tube, I would write a place for him, brother .. Regards.
08.05.2020 14:18 # 3
serFBdar
lpg mimgaz, but since it runs on gasoline in the first run, it should not be related to gas. I suspect an automatic choke or idle valve. but I need a master to tell me for sure.
08.05.2020 14:18 # 4
serFBdar
craftsmen open and close open and give money. When it doesn't exist, Allah says Allah. I am as master as they are. I use peugeot for the first time and I'm surprised. There is a malfunction in the car, we connect it to the computer, no malfunction in the car. Tofaş style trial and error were in the year 1980. Sinirli
08.05.2020 14:18 # 5
it may be caused by the aquarium. If there is a plumbing in your vehicle, it discharges the battery with a small flap.
08.05.2020 14:18 # 6
[QUOTE = EmRaH] may be caused by the aquarium. if there is plumbing in the vehicle, it discharges the battery with a small flap [/ QUOTE]
not necessarily related to the battery. As far as I understand, there is no problem like mars translation. The friend did not say anything about the mars. mars shouts, but the vehicle is not running. If the battery is weak, it is difficult to convert 2 to 3 hic.
08.05.2020 14:18 # 7
[QUOTE = serFBdar] the masters open and close open and give money. When it doesn't exist, Allah says Allah. I am as master as they are. I use peugeot for the first time and I'm surprised. There is a malfunction in the car, we connect it to the computer, no malfunction in the car. Tofaş style trial and error were in the year 1980. Sinirli [/ QUOTE]
Believe me, this kind of concealed malfunctions is not a case for pugs. it can be in any kind of vehicle. If the masters around are weak in their knowledge, they may not be able to resolve. Sometimes the problems that will not be really hiccups come to the fore and can be difficult to resolve. I hope I will get you soon.
08.05.2020 14:18 # 8
serkan.ist
What is the vehicle km? Lpg sequential system or old system? Was the engine oil filter replaced? air filter changed?
If the vehicle's KM is high, tired engines can do this. By pouring one of the engine oil additives into one engine, you temporarily dissolve it.
If the LPG is not ordered, it will run on gasoline at the first run and immediately switch to gas, but this will disrupt the gasoline system of the injection vehicles. If it is not in line, if you install a sequential system, it will recover after a while. If the old system is LPG, take the vehicle to gasoline without stopping in the evening and run it with gasoline for one minute and the injection is left in the gas.
When these engines turn the ignition, as we press the gas in the old cars, it sprays gas with the gas automatic. In other words, these cars should be operated without stepping on the gas. For this reason, as our friend said, first turn the ignition on and off without waiting on the gas and wait for a few seconds, making the rope start operation works faster.
Passing the air filter obstruction oil change time can cause similar problems.
serkan.ist 2010-07-08 11:16:37
08.05.2020 14:18 # 9
Psh
As the friend said, have the battery checked. The partner had also happened to me, thank goodness for now.
08.05.2020 14:18 # 10
serFBdar
The battery of my vehicle gayaet smoothly pressed comfortably. aba waits for 2 hours without running for at least 2 starters at the first press, it gets full and it is staggering.
08.05.2020 14:18 # 11
Psh
Take the battery to a auto electrician to have it checked. I was getting the same reactions, I went, I bought a new battery, the problem did not recur. The battery gets weaker especially during the night waiting period. You can run it at 3. Pray. Towards winter, your problem grows further.
