Working problem in the morning ...
08.05.2020 17:57 # 1
lvnt
I own 2004 Model Peugeot Partner ....
My vehicle has been working for the last 2 months, especially in the morning ...
* Starter Motor smoothly ...
* Battery without problem ...
* Diesel Pump smoothly
* There is no malfunction light
* All the maintenance is done ...
Although the vehicle goes to sleep in the evening and does not start or start at the first run in the morning, it does not run or run ... My son opens the bonnet and manually pumps the manual diesel, then press the starter from the inside and works by pumping + engine at the same time ... After working once, there is no problem during the day ...
The special Peugeot service I received in Samsun said that the latest diesel advance sender might be due to a malfunction ... 200 TL on the aforementioned piece - except for workmanship, I continue to operate manually every morning since I think it is not guaranteed to change it ...
I would be glad if you share your knowledge about the mentioned malfunction ...
Best regards...
