working problem
08.05.2020 16:24 # 1
amonse
friends 206 XS 2000 model vehicle ... I had the in-line system disassembled lpg. It has been working hard since I dismantled it ... it works at the first contact, never does 2nd but it is a little spoiled ... I think it can cause ... there was no such problem while in lpg ... I have removed the lpg since I have been doing it ... and the airbag lamp flashes for a while when I move the front seats back and forth. it gets better after a few days:) & nbsp;
08.05.2020 16:24 # 2
06OzGuR06
The airbag lamp is about the socket under the seats. There is a high probability that there is no contact in the sockets.
08.05.2020 16:24 # 3
ercan_g
spark plugs can be a problem burning gas is very easy so it takes one time but gasoline reacts a little bit later it looks like ignition problem
08.05.2020 16:24 # 4
maestro
yes, since airbag cables are under the seat, contactlessness can occur frequently.
If you disassembled the tube & nbsp; coincided with the start of the cold, you are connecting to the tube, but I think it may be from the cold.
08.05.2020 16:24 # 5
Ucyuzalti
I do not think it will have anything to do with LPG since the sequential system runs on LPG at the first run. Only nowadays, the weather got cold and it can make you fall into such an error because it is the same time to disassemble your LPG system. As for the friend, the airbag incident is done when there is contactless in the sockets under the driver's seat.
08.05.2020 16:24 # 6
Ucyuzalti
When I started writing the message, you didn't have a message, I think we wrote the same thing at the same time, I think & nbsp; "Big "LOL" "LOL"
08.05.2020 16:24 # 7
maestro
let's say the heart is against the heart ... i will not live this topic more & nbsp; i do not link to this issue superstition sir "Smile"
08.05.2020 16:24 # 8
amonse
FRIENDS FOR YOUR ANSWERS .. YOU CAN'T TAKE ANSWER EVEN AT THE PEUGEOT'S FOOL SERVICES. THERE IS A WIRE UNDER THE SEAT .. SPECIFICALLY MAKES THE CHAIR SENIOR WHEN I BACK TO THE BACK. AND 2. VISITED AT LOW SPEED AT THE GEAR ... WIPERS THE REAR FRONT FOGS AND HEADLIGHTS ARE OPEN ... THE MUSIC WAS ON, STOPED IN THE LIGHT ... (ROLANTI ADJUSTABLE DEFECTIVE ... CLEAN AS TEMPORARY) & RELEASE I RELEASE I TEND 3 E OUT AND STOPED :) THEN I RUN AND I WERE WORKED TO THE EDGE. I SAID, I SAID ..
08.05.2020 16:24 # 9
amonse
When replacing the spark plugs, the vibration and excessive white smoke cut off ...
08.05.2020 16:24 # 10
06OzGuR06
By the way, the capitalization of the articles is against the forum rules "Smile"
08.05.2020 16:24 # 11
amonse
Sorry, the president ... I notice ... thankfully, although 206 works well, it's still going ... we write it in lowercase :)
08.05.2020 16:24 # 12
amonse
SAOL'S FRIENDS FOR YOUR ANSWERS. THERE IS A WIRE UNDER THE SEAT .. SPECIFICALLY MAKES THE CHAIR SENIOR WHEN I BACK TO THE BACK. AND 2. VISITED AT LOW SPEED AT THE GEAR ... WIPERS THE REAR FRONT FOGS AND HEADLIGHTS ARE OPEN ... THE MUSIC WAS ON, STOPED IN THE LIGHT ... (ROLANTI ADJUSTABLE DEFECTIVE ... CLEAN AS TEMPORARY) & RELEASE I RELEASE I TEND 3 E OUT AND STOPED :) THEN I RUN AND I WERE WORKED TO THE EDGE. I SAID I WANT IT OUT ..
can I get an answer to that, guys ... let me take action accordingly
