wonder my battery is exhausted (solved)
08.05.2020 16:21 # 1
efsanemurat
hello friends for 2 weeks when I opened the door from my key control, sometimes I did not open the door, I did not put it on my head yesterday, I did not open it up yesterday, I said maybe it was cold, I tried it today, I did not open it again. / FONT>
myth 2011-11-18 21:59:40
08.05.2020 16:21 # 2
Does it not open with the key?
08.05.2020 16:21 # 3
efsanemurat
opening with the key it has no problem
08.05.2020 16:21 # 4
Then most likely the battery is exhausted & nbsp; "Laugh"
08.05.2020 16:21 # 5
murat abi change the battery, change the bidet, check the solders, if there is a cracked solder, it may be contactless.
08.05.2020 16:21 # 6
the battery may be exhausted or the key is dehumidified and the button or battery bed may be oxidised. A friend had a similar problem because he dropped the key into water
08.05.2020 16:21 # 7
open the key, open the battery, play it twice, maybe it will be corrected for me. yesterday I bought a cap with a snap (I got it wrong too :)) I opened the key so that I could plug it in, then I looked at the battery, the battery looks solid with the primitive tongue switch method :) I got the key back in the morning I went down and worked at the first press, & nbsp;
08.05.2020 16:21 # 8
efsanemurat
Well, I opened it, I looked at it, there is no noticeable negativity in the spotlight.
08.05.2020 16:21 # 9
Let's change the battery and try
08.05.2020 16:21 # 10
gravis_pro
Where is the & nbsp; remote control receiver of the car located? Does anyone knows? gravis_pro 2011-11-13 17:13:26
08.05.2020 16:21 # 11
Ucyuzalti
My vehicle is standing on the roof, where these lights are on the driver's part & nbsp;
08.05.2020 16:21 # 12
metin
If the control battery is running out of power, the error should read Remote battery is low on the screen. This way on 3-line displays. you probably have to have 2 lines. I do not know if it appears on 2-line screens
08.05.2020 16:21 # 13
efsanemurat
3 lines on my screen but no warning appeared on the screen
08.05.2020 16:21 # 14
metin
then the problem may not be from the battery. it may also be related to the transmitter on the remote or the receiver on the vehicle. Because when you open and lock the door near the end of the battery, even if it is from the battery, the vehicle realizes this and when you get on and start the vehicle, the Remote battery is low & nbsp; gives the error before the battery runs out. this may be another problem. Energy level will be revealed when you take out and measure the control battery anyway. I hope it's from the battery.
08.05.2020 16:21 # 15
efsanemurat
friends, I had the battery measured today, there is no problem with the battery. I wonder where the bidet 307s are the remote control receiver for what else
08.05.2020 16:21 # 16
Now when I open it on my remote, I will open it and look at it. But it does not have any problems when opening it. >
08.05.2020 16:21 # 17
ilhan abi & nbsp; & nbsp; if the toggle button has worn out more than the off button, I think it may be contactless or forced ... & nbsp;
08.05.2020 16:21 # 18
efsanemurat
Well, he did the same before, opening and closing, he was making it double or even making him do it now. He does not answer anybody who has experience with what he wrote.
08.05.2020 16:21 # 19
efsanemurat
current
08.05.2020 16:21 # 20
aspirinxlarge
Look, I will say my own solution. I thought the battery was not the same at first, but it is worth trying; & Nbsp; I don't know the exact order & nbsp; but
Insert the key in the ignition first, press the button of the unlock key a few times (maybe there is a certain number but I never counted:)
then press it out again, & nbsp; & nbsp; If not, start the vehicle and press the on button again, press the switch off again, press it again and see if the papers will be opened and closed, & nbsp; & nbsp;
I am doing what I have said above and they say that they do not introduce the key to the system. & nbsp; By the way, this solution is just as I said, and when I do this, I solve my problem. & Nbsp; & nbsp; Also, do I have a light on the switch? The red light is on and on, sometimes it is flickering.
Try it. It happens. Reviews
Page : / 2
