Wobbling-Flickering Problem in 1st and 2nd Gear (206)
08.05.2020 18:22 # 1
tlp
Hello friends
I have been facing a problem lately
The vehicle is wobbling in 1st and 2nd gear only provided it is.
The tire vibrates as if there is a balance in the tires and the gear shifts in
This problem only happens when "press the gas" in 1st and 2nd gear .
When I take my foot off the gas, the trimming stops, and when I press the gas again, it can restart.
I have not changed the right and left axle related to this problem
I did not change the gearbox wedge
What are your ideas, do you have anything? is there anyone who can hear?
08.05.2020 18:22 # 2
tlp
having an idea?
08.05.2020 18:22 # 3
Serkan
What you have said is pointing to the axle, but not doing it after the 2nd gear, which is different, you have already changed the axles, I think the masters have not found a solution.
08.05.2020 18:22 # 4
Bugra
the same thing happened to me yesterday. While lifting the vehicle in 1 gear, the right front side began to wobble as I heard the rubbing sound, but it did not.
08.05.2020 18:22 # 5
realemperor
bro, you have only one problem, room flows if you are in ankara, ugra brand peugeota is warmed up, but your only problem is there is another reason why there is another but if you want lower motor ear, there is selcuk master there, at least you will get an idea and bos at him don't spend
08.05.2020 18:22 # 6
Bugra
[QUOTE] at least wrong and not a waste of money [/ QUOTE]
The friend says he has changed axles but still continues.
08.05.2020 18:22 # 7
Moda0797
Motor ears do not spend money on other bicycles
08.05.2020 18:22 # 8
Turgay_66
[QUOTE = Moda0797] Motor ears do not spend money on other bicycles [/ QUOTE]
can be just like ears
08.05.2020 18:22 # 9
cavit cevo
friends, I changed the axes, I have the same problem, especially on ramps.
I will definitely change my ears to the engine, I changed the axles, I have the same problem.
08.05.2020 18:22 # 10
elestern
as soon as there is a knocking noise, not in the gearbox bearings
08.05.2020 18:22 # 11
cavit cevo
vehicle vibrates wobbling no sound vibrates when loaded on gas no idle
what is your comment
08.05.2020 18:22 # 12
Barut
Most likely motor ears.
08.05.2020 18:22 # 13
tlp
Friends, I will check it according to your family
the most confusing thing is that this is only the 1st and 2nd gear
no problem with others
I changed the lower engine mount, the problem continues
There is no problem with the engine mount under the brain.
It stays under the battery
I will check it too
I guess what was a bow in the axles?
come your friend to the press
I'll make him look at him
08.05.2020 18:22 # 14
realemperor
My brothers can be a room for whatever brand of money flows.
08.05.2020 18:22 # 15
muaythai
WHEN IT IS IN THE EARS, IT DOES ALL OF THIS, THE MASS VOICE IN THE GEAR TRANSITIONS.
08.05.2020 18:22 # 16
cavit cevo
I bought zero tires, renewed the axles, one wedges left, I ordered
Thank you, is it bad for me? Isn't there a friendly pejocu who solves this problem? Big smile
08.05.2020 18:22 # 17
realemperor
I have a brother in the room in Ankara, naughty brand peugeot people
08.05.2020 18:22 # 18
tlp
Friends
There is some gap when we hold the tire on the right and left while the car is on the jack, why did I do this? Will the rods swing?
08.05.2020 18:22 # 19
cavit cevo
Could there be engine ear wedges, sure miki_?
08.05.2020 18:22 # 20
cavit cevo
will anyone answer this problem?
Page : / 2
