With Vehicle Maintenance Advice
08.05.2020 21:11 # 1
samizeldestan
Friends bought a 2005 model 407 Exexutive premium 2.0 automatic gasoline car about 2 weeks ago. There is LPG in the vehicle, I usually use LPG. I don't know much about vehicle maintenance. What are the oils of the vehicle that need to be changed, and which brands of oil should I use and how many liters? Since my mother-in-law is an auto mechanic, I want to buy and change the oil from the internet or something affordable. Is there anyone who can help with this?
08.05.2020 21:11 # 2
Karacocuk24
[QUOTE = samizeldestan] Friends I bought a 2005 model 407 Exexutive premium 2.0 automatic gasoline car about 2 weeks ago. There is LPG in the vehicle, I usually use LPG. I don't know much about vehicle maintenance. What are the oils of the vehicle that need to be changed, and which brands of oil should I use and how many liters? Since my mother-in-law is an auto mechanic, I want to buy and change the oil from the internet or something affordable. Is there anyone who can help with this? [/ QUOTE] my opinion is that if you don't have a maintenance record etc, you can change all your liquids brake steering engine antifreeze etc. at least you do not know when you have changed, you do not hold anything too much engine oil how many liters you can get, but you can put a total or mobile 10/40 as a brand you can get castrolde timing set changed Did the person you bought inform you?
Go to the place that makes a good lpg assembly, have the lpg system checked and maintained
Karacocuk24 2019-03-20 22:51:02
08.05.2020 21:11 # 3
samizeldestan
The person I bought said that I just had the maintenance done. There is an oil change card or something, but I still want to have a look. By the way, when turning the steering wheel of the car, sharp bends sometimes sound like a humming noise, what could happen at the steering wheel?
08.05.2020 21:11 # 4
First of all, we wish you to use your vehicle without any accident. If you want to be comfortable, I can say a list like this.
1-Your vehicle is 4.5 liters of oil, including the oil filter. You can use total-mobile-motul as a brand. It is the viscosity suitable for your 5w / 30 vehicle.
Replace 2-brake fluid 15-20 tl 1 liter is enough.
3-oil filter - replace the pollen and air filter. Of course, first check if it is new, I think it is not necessary. Only the oil will be enough.
Have the 4-discs and pads checked. If it is near wear and tear, I would say make the change.
If sound is coming from the 5-front wheel, the bearing may be defective. Another possibility is that if the tire pressure is low or the tires are winter, sound may occur in such situations. When you lift it on the fiber, your master checks if there is a problem with the bearing.
08.05.2020 21:11 # 5
samizeldestan
Thank you for your answer. How long should the tire pressures be? If I look at the air, there are 205/60 / R16 tires on it
08.05.2020 21:11 # 6
There should be 34 psi, there are ethics at the door, and tire values are written. If it writes 2.3 bars, it is 34 psi.
