With 50 TL Fuel ..
08.05.2020 15:35 # 1
Saleeh
As soon as the warning indicator of the fuel indicator was lit a few days ago, I bought a 50 TL euro diesel from full, reset the mileage and test the vehicle's fuel performance. In city use and when the air conditioner was rarely turned on, it made 330 km until the light turns on again. & Nbsp;
How is it? & Nbsp; "Shocked"
08.05.2020 15:35 # 2
If you are a martyr, you must be very good "Thumbs
08.05.2020 15:35 # 3
Saleeh
[QUOTE = ahmetsimiz] if you made a martyr, very good, <"Thumbs [/ QUOTE]
I'm an inner city. but I'm sure the fuel will double when you're on the highway with you. You bring the man to the gas & nbsp; "Grin"
08.05.2020 15:35 # 4
anil307
What a beautiful one, look at the state of the vehicle pehhhhhh
08.05.2020 15:35 # 5
naksi
super sister mine is sometimes 250 with lpg :)
08.05.2020 15:35 # 6
Let the tool of Tuesday have a tale, let it not be evil ...
& nbsp;
Let the tool of Tuesday be less than 1.4 1.4 hdi. & Nbsp; & nbsp;
At this point, we always make incorrect comparisons.
When comparing you should compare the weight of the vehicle, power, maintenance status, tires etc.
CeCoLi 2011-06 -12 12:22:14
08.05.2020 15:35 # 7
I'm doing 160km with 50TL yaa & nbsp;
08.05.2020 15:35 # 8
Haksen016
get it with diesel vehicle so :))
08.05.2020 15:35 # 9
GokhaN
You did the super km but I don't think it's all in the city and short distance. The distance you should normally make for 50 TL is around 220-260 km. If you are traveling 15 20 km after pressing the contact, at least the normal km.
08.05.2020 15:35 # 10
revolutionary26
I travel 105 km for 50 liters of gasoline (11.8 lt). It burns soooooo much. If I had a current mind, I would buy a diesel.
08.05.2020 15:35 # 11
Saleeh
[QUOTE = CeCoLi]
Let the tool of the Tale have a tale, let it not be evil ...
& nbsp;
Let the tool of the art 206 be less than the 1.4 hdi. & Nbsp; & nbsp;
At this point, we always make wrong comparisons.
When comparing, you should compare the weight of the vehicle, power, maintenance status, tires etc.
Thank you Cem bro. As you said, the maintenance and general condition of the vehicle is very effective in this. There are no accessories other than the factory in the car, I think to install 16 wheels soon, the fuel will surely increase :)
08.05.2020 15:35 # 12
Saleeh
[QUOTE = GökhaN] You did the super km but I don't think it's all in the city and short distance. The distance you should normally make for 50 TL is around 220-260 km. If you are traveling 15 20 km after pressing the contact, at least the normal km. [/ QUOTE] & nbsp;
Generally, I used Bakırköy among hunters. When I go, I usually get stuck in traffic. I was careful not to exceed 110 when the road was empty. & Nbsp;
Result: I am happy with my vehicle :)
08.05.2020 15:35 # 13
[QUOTE = Saleeh] [QUOTE = CeCoLi]
Let the tool of the Tale have a fairy tale ...
& nbsp;
The tool of the Tune is less than the 1.4 hdi drop. & Nbsp ; & nbsp;
When comparing, you should compare the weight of the vehicle, strength, maintenance status, tires etc.
Thank you Cem brother. As you said, the maintenance and general condition of the vehicle is very effective in this. There are no accessories other than the factory out of the car, I think of installing 16 rims soon, the fuel will surely increase :)
I will ask you for 16 "lincancabab you will probably wear it :))
08.05.2020 15:35 # 14
forewer_fb
my tube insertion brother: S I am going 100 km to 50 TL :(
08.05.2020 15:35 # 15
Saleeh
[QUOTE = CeCoLi] [QUOTE = Saleeh] [QUOTE = CeCoLi]
Let it be a fairy tale, let it not go bad ... a little bit less. & nbsp; & nbsp;
At this point we always make wrong comparisons. QUOTE]
Thank you, Cem, brother. As you said, the maintenance and general condition of the vehicle is very effective in this. There are no accessories other than the factory out of the car, I think of installing 16 rims soon, the fuel will definitely increase :)
I would like 16 "lincancabur you will probably wear it :))
I think it will be like that.
08.05.2020 15:35 # 16
[QUOTE = forewer_fb]
tube insertion bro, bro: S I'm going 100 km to 50 TL :(
< / DIV> & nbsp;
As soon as we can tube you :)) You too, like me, you will be tubeed and offensive "Grin"
08.05.2020 15:35 # 17
[QUOTE = Saleeh] [QUOTE = CeCoLi] [QUOTE = Saleeh] [QUOTE = CeCoLi]
Let me have a tool, let's not look alike ...
& nbsp;
let's release the vehicle is less than 206 1.4 hd. & nbsp; & nbsp;
At this point we always make the wrong comparisons. / DIV> [/ QUOTE]
Thank you Cem bro. As you said, the maintenance and general condition of the vehicle is very effective in this. There are no accessories other than the factory out of the car, I think of installing 16 rims soon, the fuel will surely increase :)
I will ask for 16 "lincancabab you will probably wear it :))
I guess it will be like that. QUOTE]
& nbsp;
Let me try to help you when I get the rim tire,
08.05.2020 15:35 # 18
Saleeh
OK, brother. your suggestions and help are important to me :))
08.05.2020 15:35 # 19
celllat
I made 160 km with 50 TL with the method my friend said.
08.05.2020 15:35 # 20
werty
I calculated today, with whom I made 100 pounds of 33 pounds of gasoline. I filled the warehouse, I reset the km
I made 100 km, I took a gasoline, it took 33 TL. It burns a lot. my diesel car was happening: S
werty 2011-06-13 14:32:58
Page : / 2
