wipers do not throw water ...
08.05.2020 16:38 # 1
nupel307
mrb friends..307 my car wipers are running but not throwing water ... full of water..not cold in the air.
08.05.2020 16:38 # 2
okan4037
I made it broken in my previous car, I made it broken in my new car.
08.05.2020 16:38 # 3
nupel307
Sister engine is running, I think ..
08.05.2020 16:38 # 4
ekinoks44
the tip of the wiper motor may be clogged with dirt. If you did not put water for a long time, the bottom of the water comes to the engine. I had the same problem, we gave the air or something.
08.05.2020 16:38 # 5
nkre51
this week I had the engine worked
but one of them was not throwing water
I tried a little bit with a pin, it opened
08.05.2020 16:38 # 6
nupel307
may..tskler brother
08.05.2020 16:38 # 7
osmntskn
Sir, I bought a new car. I know from him that the tank can be a hole, have you finished the water? I said I'll complete, I took a look, put it from above and poured it from below.
08.05.2020 16:38 # 8
nupel307
The water in the tank is full but I did not clean the water-draining places.
08.05.2020 16:38 # 9
nupel307
Unfortunately I couldn't find the problem .. maybe it will be frozen tomorrow if the weather is sunny.
08.05.2020 16:38 # 10
kaan__
the fuse may have blown ...
if it was freezing in the past day and you pressed this way ...
the fuse of the glass water engine blows ... have it checked or get it ..
if you pull the wiper arm If there is no sound from the engine of the glass water, there is a high probability of fuse.
08.05.2020 16:38 # 11
nupel307
How can I control the brothers insurance ... they will work, but they do not throw water ... where is the insurance ...
08.05.2020 16:38 # 12
kaan__
[QUOTE = nupel307] how do I control the brothers insurance ... they will be working but not running water ... where is the fuse ... you understand
or look carefully at the fuses, if the wire inside is broken ... the backup fuse must be in the socket on the left side of the vehicle inside the vehicle where you connect the vehicle to the device
08.05.2020 16:38 # 13
aslan7333
Show it to the auto electrician, it may be clogged, the ends are often clogged with dirt. They open with a needle or thin wire.
08.05.2020 16:38 # 14
by_cadaloz
I had the same mistake. Thanks for the wash-in friend. We did not change the drum or the motor to delete. We did not change the ends, what we did. The problem is. When the bonnet is opened, the hoses coming out of the sileck engine enter the bonnet from the right side and when the bonnet is open it runs the water to wipe. does not work when closed. the water hose gets stuck when the hood is closed on the right. fix it with your hand, the problem is solved. I did it that way. I hope it will be useful
08.05.2020 16:38 # 15
cey cey
You will remove the jets that throw black water on the hood, put it in hot water and wait for a while, then you will blow the air with fresh air. solves
08.05.2020 16:38 # 16
I had the same problem last night.
08.05.2020 16:38 # 17
reis 206+
Insurance Fired. The Same Was In My Car. & Nbsp;
08.05.2020 16:38 # 18
CAGRI59
my friend opens up when the weather gets cold, 5 min work from inside and outside is caused by dirt mostly ..) & nbsp;
08.05.2020 16:38 # 19
nupel307
problem solved friends .. tskler for your information .. fuse ..
