wiper water tank
08.05.2020 15:15 # 1
arslan_1905
friends I want to ask, where is the wiper water tank?
Let me explain that we bought 307 but I could not see the horn, it does not ring, I could not find the water tank.
please help
08.05.2020 15:15 # 2
mdincer34
When I open the hood of the vehicle, I will say on the right side of the vehicle, that you do not have a wiper tank, the vehicle did not disassemble it, but I do not know if the car's headlight is in that corner.
08.05.2020 15:15 # 3
when the water tank opens the hood, on the left side behind the headlight
08.05.2020 15:15 # 4
:) In peogeouts, the mouths of the wiper water tank caps generally appear. You may not have seen the tank so that the mouth is not raised.
08.05.2020 15:15 # 5
F-Eren
First click on the link below and read ...
08.05.2020 15:15 # 6
[QUOTE = pugti] :) In peogeouts, the wipers of the wiper water tank caps come out. You may not have seen the tank so that the mouth is not open [/ QUOTE]
Exactly those covers are breaking immediately.
08.05.2020 15:15 # 7
Ask for the water with a blue cap. This picture is not quoted from 307 but the type is the same.
08.05.2020 15:15 # 8
volkan_uysal
Hello, hello Sinirli
08.05.2020 15:15 # 9
307P
[QUOTE = volkan_uysal] Aleyküm hi Sinirli [/ QUOTE]
Don't be my sister Sırıtma
08.05.2020 15:15 # 10
metin
When you face the vehicle, you will see the cover behind the headlight on the left and fill it there. If you search for the tank, it is also behind the bumper under the headlight.
The quote is from an older brother (:
08.05.2020 15:15 # 11
azdek
When you open the hood, there is a windshield wiper on the left side behind the headlight ...
08.05.2020 15:15 # 12
ekinoks44
Mine has no cover :) Can we assure that it doesn't look nice ..
08.05.2020 15:15 # 13
motoberk
Available in spare parts, you can also find it on the Internet. For example, I bought it for 3 liras.
08.05.2020 15:15 # 14
kaan__
everybody told me about the glass water tank so i'll tell you the horn Göz Kırpma
right above the right fender hood, it is either completely absent or its socket is removed, but it is very difficult to see the hood without disassembling it.
08.05.2020 15:15 # 15
zavur
I don't have a cover for 306 tada and the hole is just a cover
08.05.2020 15:15 # 16
[QUOTE = arslan_1905] friends I want to ask where is the wiper water tank?
please help
When the wiper finds the water tank, check if it is pouring water, and there may be cracks. If there is no crack, there may be a problem with the water spray engine. The holes may be clogged.
08.05.2020 15:15 # 17
cetin
I filled the glass water reservoir of 206 to the full brim, but some of it flowed from the bottom. Ouch
08.05.2020 15:15 # 18
cetin
date.
08.05.2020 15:15 # 19
If it is not completely emptied, there may only be cracks in its upper part.
08.05.2020 15:15 # 20
cetin
no, it doesn't drain completely. It only fills up to the bottom of the pipe extending upwards.
Page : / 2
