wiper water
08.05.2020 16:02 # 1
exssen
Guys, the windshield water engine had failed, but this time it doesn't bring it to the level I want. Do you have a setting friends? Or is the power of the new engine not enough? (2004 307 xs) the albaydemirc 2011-08-23 14:33:54
08.05.2020 16:02 # 2
Engin Tepe
You can make adjustments with the help of the needle where the squeegee splashes water. If there is no room, it may be clogged by keeping strong air in reverse.
08.05.2020 16:02 # 3
tayfundoner
It was the same with us, it was broken, the water engine changed, but now it was wet the glass first, then the engine was working then the wiper was working now, the wipers are a round of calcio at that time, the dust on the glass, both the glass scratches and the wipers die.
08.05.2020 16:02 # 4
lamblia
a few months ago I threw the wiper water from the polisher and stain remover tablets. The wipers worked for a few days, but then the water started to come out from the sprinkler. I cleaned the tank thoroughly. I opened the inside of the engine. There is a black round gasket inside the motor that regulates the passage of water to the front and rear sprinklers. It was swollen and unable to move. I tried to remove it, but some of it was deformed. I sanded the inflatable parts and put it in place. water was coming from the back when I started it. I bought a new engine for 30 TL and put it back in. Now there is no problem. If you carefully remove that plastic and sand it in place to move freely, replace it, your problem will be resolved.
