wiper problem ???
08.05.2020 16:34 # 1
kudret_yildirim
When I turn my car erasers on and off, instead of going up and down to the bottom of the window as it should be, it stays where I closed it. only intermittent wipe mode is working correctly. what is the solution to this ...
08.05.2020 16:34 # 2
djchaos
does it stiff? from the wiper motor, there may be a reception problem
08.05.2020 16:34 # 3
kudret_yildirim
it doesn't hold up like that ... it just stops when I close it during normal operation. not fulfilling ...
08.05.2020 16:34 # 4
djchaos
If you have a good electrician, there may be a malfunction in the wiper motor. I think a malfunction from the engine automatic does not automatically download.
08.05.2020 16:34 # 5
[QUOTE = kudret_yildirim] When I run my car eraser on and off, it stays where I closed it instead of going down to the bottom of the window as it should be. only intermittent wipe mode is working correctly. I wonder what the solution is for this ....? [/ QUOTE]
Let me tell you where the problem is. It is very common in the 306s and is completely due to the negligence of that area of the vehicle. If you use it this way, your wipers will become inoperable after a short time. The problem is water:
Your wiper motor is strongly wrapped with possible ice and filled with water until it is throat. The reason is the obstruction of the drain hole. The passing of the cables to this expense is one of the factors that facilitate the obstruction of this point. You need to do that part and take care of it. Reviews
08.05.2020 16:34 # 6
kudret_yildirim
[QUOTE = koliva] [QUOTE = kudret_yildirim] When I run the eraser of my car and closed it, it stays where I closed it instead of going down to the bottom of the window as it should. only intermittent wipe mode is working correctly. I wonder what the solution is for this ....? [/ QUOTE]
The weather is very nice in Bursa today. I'm going to check out what you say right now ....
