wiper motor cable
08.05.2020 19:31 # 1
hakao
In my car, this cable is separated. If I combine the wiper motor, I think it will be a problem. The wiper does not work in 1 2 position.
08.05.2020 19:31 # 2
The problem is related to the broken cable. When the contact is closed, assemble it, it will be a problem, but you will need to isolate it well. I also did not understand how he was broken, someone like pulling it off. sonerkyl 2015-11-23 12:01:50
08.05.2020 19:31 # 3
hakao
Thanks for the answer, it was a little late, but the repairman took it to the friend, tied it up, wiped the cord 3 4 times it stopped but stopped on the opposite side, the friend said from the wiper arm, I took it to another electrician, he said from the wiper motor, not from the arm. There is only front wiper, trouble wiper motor, non-original 60 80 TL arm 100 TL, I did not know exactly which one was unstable. Is there any method I can test thanks
08.05.2020 19:31 # 4
my teacher wiper time relay may be malfunctioning. working right now but I think it's on the opposite side. and my teacher, disassemble and clean the socket there. sonerkyl 2015-11-30 16:37:25
08.05.2020 19:31 # 5
hakao
It does not work exactly 1 2. When the cable is disconnected as above, when it is connected to the cable, it works by itself 5 or 5 times and stops fully raised. When the cable is disconnected, it only works in Tier 3. The problem was either on the arm or on the wiper motor, they could not say from the 100% arm or motor in two masters. If I change the arm, the problem may continue. If I change the motor, the electric masters of our arm are not very good. So the problem is I have to test my motor seat myself somehow
