wiper does not throw water
08.05.2020 19:41 # 1
akyuz.cagri
Hi friends, I have a problem with the glass washing of the car. It does not throw water. When I whisk the arm, there is no sound to come from. There is a small engine. ?
08.05.2020 19:41 # 2
talip206
If the engine is intact, check the fuses under the steering, possibly fuse has blown. If the fuse is good, there is a problem in the arm.
08.05.2020 19:41 # 3
OguzhanKucuk61
My sprinkler on the left is not spraying straight. It beats slightly to the right and slightly above what it should be. What is the solution ?
08.05.2020 19:41 # 4
[QUOTE = OguzhanKucuk61] Nor does the jet on the left side spray straight. It beats slightly to the right and slightly above what it should be. What is the solution ? [/ QUOTE]
You will adjust it yourself with a pin, attach it to the spraying nozzle of the teacher nozzle, then adjust it where you want it to be.
08.05.2020 19:41 # 5
OguzhanKucuk61
[QUOTE = sonerkyl] [QUOTE = OguzhanKucuk61] Nor does the jet on the left side spray straight. It beats slightly to the right and slightly above what it should be. What is the solution ? [/ QUOTE]
Thank you, teacher, I'll try it at time available
08.05.2020 19:41 # 6
obayazit68
Sir, I have 206 HDI models in 2003.
They played with the holes of the windshield sprinklers and broke it. I bought a new one from the service. The problem, which was in the past, continues in this.
Problem; the water going to the upper part of the glass and even to the ceiling.
As you said to solve, I said, let's adjust the direction with a needle. When we look at the fountain, it is thought that it can only move on the vertical axis, but it does not move.
It was possible to make adjustments with a pin or a screwdriver, as you say, in the different model cars I used.
But it is not possible in this model.
I couldn't adjust it, the bottom of the glass still remains dry and the top and the ceiling get plenty of water.
What is your opinion. Does the sprinkler of another model fit my vehicle
or what should i do
Remi is in the link below
obayazit68 2016-07-22 14:51:43
08.05.2020 19:41 # 7
OguzhanKucuk61
[QUOTE = obayazit68] Sir, I have a 2003 model 206 HDI.
or what should i do
The same thing happened to me in the message you saw above, the left breast was squirting up and to the left. Soner solved the situation with the advice of the brother using a needle. A fine needle will not work. When the bag is thick, a needle works and you can really give the direction you want.
08.05.2020 19:41 # 8
ilhanozgur
Hi friends, the wipers of my Peugeot 206 are working when I try to throw water to the front wiper, the wipers are working normally, the wiper water motor does not work and does not throw water. But there is no problem with the rear wipers.
08.05.2020 19:41 # 9
KILIC
If the engine is running, it may be clogged.
08.05.2020 19:41 # 10
ilhanozgur
The engine only works when I try to throw water on the rear wipers. No sound when I want to throw water on the front wiper.
08.05.2020 19:41 # 11
KILIC
then it is probably insured.
08.05.2020 19:41 # 12
ilhanozgur
I know that the front and rear wipers have only one fuse, should the fuse blown, shouldn't the water in the rear wiper blow? I'm asking because I don't know, don't get me wrong. I'm afraid of the arm
08.05.2020 19:41 # 13
maximusti
[QUOTE = is ilhanozg]
If the front and rear wipers have a single engine, the front hoses or nozzle are clogged.
but it can be motorized separately.
You can open the ducts by removing the front nozzles, giving air with the compressor, you can do the same in the hose, but be careful, water will squirt out of the water tank.
but if there is a double engine, the engine of the front may be defective.
08.05.2020 19:41 # 14
boruc
If there is an engine noise, the hose may also be broken.
There was no water going to my rear window, we checked that the broken water was dripping from the bodywork to the floor :)
Next to the tailgate, we opened the part where the cables came and made an additional hose
08.05.2020 19:41 # 15
ilhanozgur
When I want to throw water to the rear wiper, there is engine noise and it beats but when I want to throw water to the front wipers, there is no sound from the engine, no water
08.05.2020 19:41 # 16
KILIC
As far as I know, teacher, there is only one engine. When you throw water in the back, the sound of the motor is heard, but when you start it, you say that the sound of the motor is not heard, so there is no obstruction in the breasts. No electricity to the motor. In this way, two options remain. either arm is broken or front and back fuses are separate.
08.05.2020 19:41 # 17
ilhanozgur
We seem to be solving this problem with everything that I am afraid of, because I looked at it in insurance only :(
08.05.2020 19:41 # 18
KILIC
I hope it is not arm. You can still disassemble the nozzles and try cleaning them. Keep it in the descaler for 2-3 minutes, then give it a try.
