Wiper Command Does Not Finish
08.05.2020 21:11 # 1
74emre
Hello friends. I am writing from Bart. My car is 2004 model 307xr. My problem is that the wiper command does not finish. It keeps running when I run the tool and command the wiper and when I hit the zero command. They said arm malfunction, I got the arm, but it was not arm. This time they said wiper motor. I would appreciate if there are friends who have a wiper motor in hand or give an idea that will help you like a different repair. Thank you from now
08.05.2020 21:11 # 2
recepagdas
I do not think that there will be a wiper motor, there is no material to instruct the teacher to stop and start inside the engine. The vehicle is commanding him to delete it as well. Your signal arm transmits bsi to bsi, and the relays in the fuse box give voltage to your motor and cut it off. In other words, if the wiper motor is stopped or not, it is clear that if it can be deleted, it will not be decided by itself. There are relays, even when running gradual wiping, it deletes it as cit and throws it back as cit. Maybe it doesn't stop deleting if it sticks to the role in such a situation? Or you need to have a control. installation check may be required. Leave it to an electronics store that can connect to a Peugeot computer if it's not a relay. Because there is a command in his brain, he looks like what he has given in his brain, you would actually see the command given by your wiper arm instead of trying it by changing the wiper arm and you knew that the problem was not with him.
08.05.2020 21:11 # 3
I agree with what our +1 recep friend said. In addition, there is an electric accents made later in the vehicle like xenon-sound system-american park.
08.05.2020 21:11 # 4
74emre
Are you in trouble? No, there is nothing in addition to the vehicle, just a tape recorder. I also replaced the battery as zero 2 months ago. Now should I have to look at him in my troubled roles ???
