Wiper Arm Calls Glass
08.05.2020 20:58 # 1
peugeot207
When the wiper arm is operated, it makes heavy noises.
left wiper arm touches glass
how do i solve
how could this happen?
08.05.2020 20:58 # 2
Selcuk55
Replace the squeegee blades, the children touching the glass on their arms may be twisted slightly bent upwards
08.05.2020 20:58 # 3
onurrr41
You can bend it with your hand so as not to break it.
08.05.2020 20:58 # 4
GokhaN
check the screw on the port, replace if the wiper broom is old.
08.05.2020 20:58 # 5
x571
[QUOTE = peugeot207] When the wiper arm is operated, it gets heavy and loud.
how do i solve
We'd better understand if it was a video, but if the arm is touching, the plastic of the broom may be broken. but then it draws the glass pretty. If it sounds like tar tar tar, it has become hard. There is no other solution that you will replace. I recommend bim and shock wipers. they are very quiet and durable.
08.05.2020 20:58 # 6
peugeot207
I'll try to take a picture. After leaving the service, it contacts the Wiper Arm, which is attached with the screw. From the bottom. I changed the wiper arm, and it started to sound more. Not from Supurgen. I put back the old baseboard. I inserted the handle from the screw and inserted it. The smell of the sleeve was strange and I did not twist on it. Even if I slightly twisted the tip of the arm, the sound is still coming. If I remove the hood? It rains every day, young! How Cozecem?
