Wiper and Headlight Arm Malfunctions
08.05.2020 17:31 # 1
altantezcan
Since I could not enter the forum for a long time, I was away from a lot of things. First of all, hello everyone. My friends said the switch on the wiper arm of my car did not change when I pressed the malfunction or it changes afterwards. There is a contactlessness. Around 400 lira. I want to disassemble and look into it, probably it has a small malfunction, but I could not understand how to disassemble the steering wheel and the arms, and after removing the arm, I would like to know if there is an idea that I can not open it. If there is a good peugeut service, I ask them to say, does anyone know of a solid master who will not say that everything should change :)? Thanks in advance ...
08.05.2020 17:31 # 2
Memed8572
THERE WAS A SUBJECT SUBJECT TO THIS PICTURE HOW MANY OPERATIONS OF THE BUTTON WAS CONTINUING TO OPERATE THE ROAD COMPUTER.
08.05.2020 17:31 # 3
altantezcan
I searched quite a bit but I couldn't find it, let me look again, thank you.
08.05.2020 17:31 # 4
Memed8572
AND THE BUTTON THAT CHANGES YOUR FAILURE ROAD COMPUTER?
You said that the headlamps to be wiped are faulty.
WHAT DID YOU LIKE THE ROAD COMPUTER KEY IN CONTENT WHICH FULLY UNDERSTANDED DEFECTIVE?
08.05.2020 17:31 # 5
altantezcan
The button on the end of the wiper arm actually has a problem with the signal, but this more important title is wrong, yes, let me see if the warning is changing for your warning.
08.05.2020 17:31 # 6
Memed8572
http://forum.peugeotturkey.com/forum_posts.asp?tıd=16691&kw=yol+b%ddlg%ddsayarı&title=peugeot-206-yol-bilgisayar-com2000-tu-yapm
SEE IT FOR THE COMPUTER KEY MAYBE MAY HELP YOU.
08.05.2020 17:31 # 7
hsnsnl
teacher, there is oxidation in that key, great chance .. there is a contact sprays without opening anything. .. You can insert 1-2 more things .. the back piece of the back wiper is frozen in the frozen part, but if you lose the location of the path inside, it may take time to return to normal.
08.05.2020 17:31 # 8
altantezcan
Thanks to the link you gave memed8572, I removed the key, thanks.
08.05.2020 17:31 # 9
GokhaN
We now have the full com2000 campaign product. The price is 280 TL.
08.05.2020 17:31 # 10
GokhaN
I have one product in my original hand as a campaign. The price is 300 TL. Gokhan 2013-04-18 14:52:14
08.05.2020 17:31 # 11
Gokhan Cetin
[QUOTE = altantezc of]
you can disassemble the exact red place in the line, you can see the future better
08.05.2020 17:31 # 12
altantezcan
I do not understand how to dismantle that area.
08.05.2020 17:31 # 13
altantezcan
I pressed the spring inside with a screwdriver, but it didn't change, but it does sound but it doesn't change
08.05.2020 17:31 # 14
plawert
I know that the part marked with red is connected to the middle gobege with a film, so you have the possibility to break it while inserting it, so it is useful to be careful.
08.05.2020 17:31 # 15
arachnid
I will not be able to answer the problem with altitude but I was very curious. Did you remove the wiper arm without removing the steering wheel and how it turns out. Can you tell.
I want to say something. the glass button was broken in me. clicks sounded but did not work. I had found and replaced the complete exit.
As you said, if you change the button you pressed with a screwdriver. I hope you will disassemble.
08.05.2020 17:31 # 16
altantezcan
First of all, I am sorry, because I gave the answer late. I did not disassemble the wiper arm, I just removed the upper button and the rear wiper mechanism. To remove it completely, it is necessary to remove the steering wheel together with the signal arm. but in general it changes with a little play.
08.05.2020 17:31 # 17
arachnid
I got it, buddy. According to the second photo, I thought you removed the steering wheel without removing it. glad you did. headlight wiper is sold complete and very expensive. I broke it. I know from there.
Get well soon.
