Winter Tire
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 5008
08.05.2020 21:03 # 1
bluewave
mrblar .. Friends who use winter tires, I know that the casti size of our vehicle is 215 50 17. However, I see that some brands use 205 50 17 instead. I wonder if anyone uses 205 tires. Would it be a problem to use
08.05.2020 21:03 # 2
HasGur
[QUOTE = bluewave] mrblar .. Friends who use winter tires, I know that the casti size for our vehicle is 215 50 17. However, I see that some brands use 205 50 17 instead. I wonder if anyone uses 205 tires. Would it be a drawback to use [/ QUOTE]
Although it is not very important if you are constantly driving in the city;
  • Tire height of 215/50 R17 tire with base width 215 mm 215x50 / 100 = 107.5mm
  • Base width is 205 mm Sidewall height of 205/50 R17 tire 205x50 / 100 = 102,5mm
In other words, if there is a difference of 5 mm between the two tires and the rim of the tire, instead of 215, the height of your vehicle will decrease by 1 cm, the comfort will decrease a little, the risk ratio of the tire's cheek failure will increase, but 205 will be more suitable if you have to wear a chain.
195/55 R17 tire It provides a much safer road on wet ground with the same vehicle height as 215 . I on wet ground As the width of the base increases, the speed at which the tire begins to swim decreases, the skid increases in the snow, however, as the width of the base decreases on dry ground, the braking distance increases.
Hasgör 2018-10-30 18:50:04
08.05.2020 21:03 # 3
bluewave
Thanks a lot for your information, as far as I understand, it will be more convenient to buy an original size tire, although there is not much difference apart from the details. According to my research, there is not much price difference between these two dimensions.
08.05.2020 21:03 # 4
Note: As a teacher, I have the capacity to carry the vehicle to the vehicle.
08.05.2020 21:03 # 5
Levent206xt
The length of the 215 tires is transverse
The sidewall size of 50 tires is the part that touches the road with the rim.
17 is the rim size
There is no multiplication and division, whatever the cheek length is.
08.05.2020 21:03 # 6
HasGur
[QUOTE = Levent206xt] The length of 215 tires is transverse
17 is the rim size
You made me laugh out loud Smile
When searching the answer to ask 2 questions, the information is refreshed ... In order not to mislead people!
1- What is the unit of the 50 number you call cheek length?
2- What is the unit of the 17 number you call rim size and if this number is not mm , how can it be converted to millimeter without math?
Whether it's multiplication or division, math is one of the things to love / learn, there is a lot of math behind everything from meteorological predictions to the design of cars, and the scope of mathematics is still not fully expressed!
08.05.2020 21:03 # 7
Levent206xt
Nothing to laugh, go and ask the tire dealer you want. 211 base width equals 21.5 cm.50 sidewall size is 5 cm equivalent.
08.05.2020 21:03 # 8
HasGur
[QUOTE = Levent206xt] There is nothing to laugh about and ask the tire dealer you want to go to. 211 base width is equivalent to 21.5 cm.50 sidewall size is 5 cm equivalent.17 rim size. [/ QUOTE]
You are right, the primary problem of the country is that almost everyone thinks that they know everything ... That's why the Turkish content on the internet has turned into a dump!
08.05.2020 21:03 # 9
RP393
[QUOTE = HasGur] [QUOTE = Levent206xt] There's nothing to laugh about, go ask the tire dealer you want.215 base width is 21.5 cm equals.50 sidewall size is 5 cm equivalent.17 rim size. speech is here. [/ QUOTE]
Interesting Shocked tomorrow morning my first job is to measure my 50 sidewall rubber and see how many 5cm it is doing Big smileBig smileLOL
08.05.2020 21:03 # 10
tsufrankwoli
17 is the rim size
The second figure is in percentage. It is calculated according to the base length.
You can look after the second minute.
08.05.2020 21:03 # 11
friends, please don't give offensive answers to each other. Let's not get out of the frame of respect and love.
