winter tire
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 17:08 # 1
gngburak
okaysamsam friends
If we now wear winter tires, do not we have to wear chains on snowy roads?
08.05.2020 17:08 # 2
Mami86
I know as a non-chain studded snow tire, the winter tire has more surface that touches the ground, provides better adhesion on the wet surface, burns more fuel because the friction increases, of course, this definition is not entirely my definition.:) & Nbsp;
08.05.2020 17:08 # 3
rataylan
When you use the winter tire in summer, the vacuums on the tire will lose its property and exfoliate due to hot weather and road. Road clutch and braking distance will also be weakened. However, it is certain that tire sales will explode. In Ankara, all of the road cleaning and salting vehicles are used.) .
Reviews
08.05.2020 17:08 # 4
tellotello
Depending on the condition of the road and the condition of the tires, you will not need to wear a chain, but it will not eliminate the possibility. Fuel performance and wet ground performances are generally better than for summer ones. Another difference may be in road sound. The deformation of the wintry that will continue to be worn in the summer will increase and will not provide long life. Because the sellers come to their jobs, they are spreading "Brother was obligatory" and they are very successful as far as I can see in this. Let me have a winter tire for everyone when it snows.
08.05.2020 17:08 # 5
hema123
As someone who has been using winter tires for 20 years, I would like to correct some misinformation and share some information. - "silica" in the composition of snow-winter tires is more than summer cottages. Due to the excess of this substance, it does not immediately lose its softness, like summer tires in cold weather. The hardening that causes aquaplaning will be less. Winter tires, which have a generally lamellar pattern, increase adhesion on slippery surfaces. provides better adhesion than flat surface patterned tires. - The surface drainage channels are wider in snow-winter tires. therefore, the surface stepping on the ground is small. Therefore, the grip on the ground increases as the weight of the vehicle per cm-square will be higher. choosing a very low tire will be more efficient. For example, if the cottage 175/65/14 is used, it is better to use the winter 165/70/14. If this is not possible, the same size should be used, and the larger one should be avoided. Snow-winter tire should be used in every wheel. If it is attached to the front, the rear sliding becomes inevitable. Winter tires wear out faster. but it can be used in the summer if it is over 4 years old and has a depth of more than 3mm. Since the summer will show tire behavior due to hardening due to aging, winter use should be avoided. - Studded tires may be an alternative to the chain. studless snow-winter tires will not work without chains in harsh conditions. There is no alternative to the chain on thick snow and soft ground. - There is no such thing as a vacuum. this vacuum word is a completely fitting term. snow barracks provide better adhesion to the ground with soft silica pulp structure, deep and wide discharge channels and lamellar tread pattern structure. that's all. - When used in winter, the winter tire saves fuel. If it continues to be used in summer, it does not consume excess fuel, but it will wear out more quickly. but you should definitely use it at the highest recommended pressure value for your vehicle. If it is used with low pressure, both winter performance will be low and it will cause excessive consumption in summer use. - Winter tire's contribution to braking is much more than its contribution to traction. this is the main purpose. If used with the right measure and the right pressure, the rolling resistance is so negligibly small. hema1232012-11-13 22:50:12
08.05.2020 17:08 # 6
gngburak
Thanks for the information you provided ....
08.05.2020 17:08 # 7
gngburak
[QUOTE = 307 bursa] If you keep wearing winter tires, you do not need to wear a chain, if you keep using winter tires in summer, road noise will increase in your vehicle, fuel increases etc. etc.
izmir there is not much snow, i am now in urfa, i will go to izmir on february 15 i did not use any car in the snow.malum konya it is snowy and cold between the butler i could not decide exactly whether i buy a winter tire
08.05.2020 17:08 # 8
murat20021978
Make sure your vehicle is fitted with a winter tire. Our hema123 member explained it very well. The vehicle without a winter tire has a much higher risk of an accident than a winter tire. Remember, people need a tire in their vehicle just like they wear summer shoes and winter shoes when it comes to winter; & nbsp;
08.05.2020 17:08 # 9
gngburak
[QUOTE = 307 bursa] [QUOTE = gngburak] [QUOTE = 307 bursa] If you keep wearing winter tires, you do not need to wear a chain, you can use the winter tire in the summer, the road sound will increase in your vehicle, fuel will increase etc. etc. I know that there is not much snow there in summer and winter :)
< / DIV>
Izmir is not much snow, I am now in Urfa, I will be in Izmir on February 15, I did not use any vehicles in the snow. I guess it is snowy and cold between the butler, I could not decide exactly whether to buy a winter tire or not. [/ QUOTE] < DIV style = "DISPLAY: n o ne" id = isChromeWebToolbarDiv>
I said that you are in Izmir, but the winters pass a bit hard in the east and if you do not have experience in the snow, I definitely recommend you to wear a winter tire & nbsp;
[/ QUOTE] thank you
I want to say one more thing
I will buy a tire and steel rim, what is the difference between 185-55-15 or 175-65-14?
08.05.2020 17:08 # 10
Bugra
175-65-14 are the original factory tire sizes, except for sports models of 206. & nbsp; 185-55-15, in contrast to the original, there is not much difference, I think the decision is up to you.
08.05.2020 17:08 # 11
gngburak
[QUOTE = bugrature] 175-65-14 are the original factory tire sizes except 206 sports models. & Nbsp; 185-55- I guess the decision is up to you, as it is in contrast with the original of the 15.
