Winter Has Come The Problems Begin - Help
08.05.2020 20:05 # 1
tolga.onal
4 days ago, the weather was quite cold, I pulled the hand brake, the left rear wheel was locked, it rotates when it speeds up, but it is constantly braking, the car forgot again yesterday and pulled the handbrake again, and this morning the two wheels of the rear wheels are reversed when the speed is canceled, but when it slows down, the bidet locks when there is snow. In case I came 6 km long, I was burning like a morning hawker :) What solution can we find for this?
Secondly, this also started to be new, while the vehicle warms up well when idling or at low speeds, but when it accelerates a little, the temperature of over 50 km decreases even if the heater is not open, it goes up to zero even if it is not open. We couldn't make those peugeot love winter :)
08.05.2020 20:05 # 2
Teacher, the problem of hand brake freezing can be encountered in many vehicles. You will bend under the rear wheels and see the handbrake wire, and it stays plugged in. Usually, you need to move it with something like a hand or pliers, and the reason is that water is filled into the pipe where the brake wire passes.
2. I guess your thermostat is not closing itself, it may be broken. I do not fall below 70 when I accelerate. I also say measure antirysis.
08.05.2020 20:05 # 3
talip206
1. You won't have to apply the hand brake, there is no other way. In these weather, it freezes regardless of its brand.
2. Possibly the thermistat is defective or your vehicle does not have a thermostat. If you continue in that way, the engine will wear out too much.
08.05.2020 20:05 # 4
tolga.onal
I think of a thermostat, but it can be up to 90 while waiting at low speed and idling, but I think that the car will not get hot even if it does not turn off the thermostat, but I also filled the antifreeze 2 weeks ago, but there is also a water shortage. we drained the water in it completely, but not from the hose below, from the water tank to the radiator, from the thin hose on the radiator, and then that hose did not fit properly, I think the latch was broken from there, some water is missing from it, maybe it could not be able to apply enough pressure from it.
08.05.2020 20:05 # 5
when the road tolga has nothing to do with it, it is natural to warm up because cold air does not hit the engine. when moving, the water in the radiator becomes icy and the room rapidly lowers the temperature. wonder about the piece
http://www.peugeotmarket.com/peugeot-307-16-benzınlı-ek-depo-hortumu,pr-2461.html
08.05.2020 20:05 # 6
tolga.onal
It looks exactly like this, the pipe from the place where I put water to the upper edge of the radiator was such a thin thing. I understand that he said that if I closed the front of the radiator with cardboard for now, it will manage me like that until the snow disappears.
08.05.2020 20:05 # 7
If your problem is not a very expensive piece, as the thermostat tolga says, replace the material situation if it is available. 1-2 liters of antifreeze goes from 45-50 TL thermos. Get 100 TL or something. sets something master in the cuff.
http://www.peugeotmarket.com/peugeot-307-16-benzınlı-termostat-orjınal,pr-5928.html
