winter came vehicles
08.05.2020 17:05 # 1
sosyete_60
friends, i have a peugeot 206 1.6 16v last year i put the poettin long life antifreeze this year i will replace it, how can i put 2 lt antifreeze 1 lt water how is it all getting 3 lt or something
08.05.2020 17:05 # 2
ssertbakan
Antifreeze and the amount of water is related to how many degrees & nbsp; you will protect your vehicle. Mixture and degrees of protection are written on the antifreezes related to this. Mixing for -30 is different Mixing for -10 is different. This is about what you need.
08.05.2020 17:05 # 3
tellotello
As far as I know, the antifreeze rate in the system can be as high as 70 percent (for you, not as you put it, for the total water in the engine assembly, and as it gets closer to 70 percent and things start to increase, the reversible freezing point will increase up to -37 degrees. If you practice according to this rate, there will be no trouble. Based on the information I got from another web page, a table was created as follows: Volumetric Mixing Rate Freezing Temperature 100% Water 0 ° C 90% Water + 10% Glycol Mixture -3 ° C 80% Water + 20% Glycol Mixture -8 ° C 70% Water + 30% Glycol Mixture -16 ° C 60% Water + 40% Glycol Mixture -25 ° C 50% Water + 50% Glycol Mixture -37 ° C 40% Water + 60% Glycol Mixture -50 ° C 30% Water + 70% Glycol Mixture Case <-50 ° C 20% Water + 80% Glycol Mixture Case -45 ° C 10% Water + 90% Glycol Mixture Case -28 ° C 100% Glycol Mixture i.e. antifreeze -12 Resources : http://www.friterm.com/getattachment/3ea92381-eb6a-4a91-bc7f-76e6be93b376/385.aspx (page 2 - Table 1. Go to Antifreeze Rate re Freezing Point of the Mixture) http://hondakolik.com/foodli-bilgiler/antifiriz-su-karisim-oranlari-ve-antifiriz-hakininda-bilgi/I hope it helps. In the meantime, it does not mean that a heading needs a correction in the winter as it requires an antifreeze in our summer and winter vehicles.
