windshield replacement comment please
08.05.2020 18:55 # 1
ibanez_022
friends have you ever experienced glass replacement? The windshield of my vehicle has been changed at the authorized service. From where the passenger seat is, the silicones are overflowing, it looks very bad .. do you think they can fix it on Monday? Would it be a problem if they remove the glass and put it back on?
08.05.2020 18:55 # 2
herry
If they try to clean the silicones without inserting the glass, if the image does not recover, they insert the silicone completely and remove the windshield, and they do the assembly work again. no problem.
08.05.2020 18:55 # 3
ibanez_022
After removing the glass, the sticky residues on the glass, etc. and I was so tempted.
08.05.2020 18:55 # 4
herry
If there is something that doesn't bother you, they should definitely do it properly. After all, nobody is doing any good for everyone. I do not think it will be too tiring because the glass is just installed, dismantling.
08.05.2020 18:55 # 5
ibanez_022
Of course they will do it, or I will write until French .. But why do I get nervous when I can do like a man?
08.05.2020 18:55 # 6
herry
[QUOTE = ibanez_022] of course they will do it or write it up to french .. but why do I get nervous when doing like a man .. [/ QUOTE]
Unfortunately, it works like this, thanks to the traffic, we often spend time in the car from home. you are right. I hope it is done beautifully without difficulty. You write us the developments.
08.05.2020 18:55 # 7
ibanez_022
of course don't worry ..
08.05.2020 18:55 # 8
samet206
If you do this way, you will wear yourself a lot, you will spend yourself when you say that the car is smooth, unfortunately, if we are in the authority, we are experiencing such problems, especially if I am a meticulous person, but if there is no situation that will create a lot of trouble, I will ignore it. the car does not show its care, but if it is a very bad situation, you have the right to appeal until the end.When it comes to the problem, the windshield may overflow the silicone, but the important thing here is whether it gets water or not, in such changes, people will have the problem of getting water in the windshield later. .
08.05.2020 18:55 # 9
ibanez_022
I take your picture and send it, teacher, even a person who is not meticulous will rebel so bad .. so bad from inside the car.
