Windshield opening and closing regulations
08.05.2020 19:11 # 1
transform609
Greetings everyone, friends .. I have a malfunction that I think is chronic for the 307s.
1-The driver's side opens when glass is closed
2-80% same problem when pressed and closed longer than the central lock (driver's side)
3-The moment I pull my hand from the glass shut-off button, the motion is interrupted (If it closes smoothly, that moment, even if it doesn't open when I say close, the moment I pull my hand stops, normally it has to close itself)
4-Long-pressing the glass control buttons on the driver's side, I know that the "snap" sound is heard.
5.This "do not open when I say close" is sometimes on the passenger's side, but it is okay to open and close automatically with one touch
6-Es accident, my hand is on the window control of the driver's side, if the rear window controls are on, the rear windows start to open, you only need to use the window control on that rear door, it does not matter whether the driver opens the window control, the rear windows open in the capacity.
7-With my best regards for peugeot, who made such complex and long sentences Angry
Friends, I hope I could explain it because the problem looks like the glass controls, it looks like the glass motors, it looks like a jam in the mechanism, what do you think I would do
08.05.2020 19:11 # 2
trabzonlu207
What nonsense this is.
08.05.2020 19:11 # 3
transform609
Exactly, the pilgrim has cooled me from the car :(
08.05.2020 19:11 # 4
oguzhan53
The same problem exists in me for 2 years. If I clean the control circuit with dry circuit cleaner, I think the problem is with the glass motors. There is a solution, I hope we get rid of this trouble. oguzhan53 2015-03-25 11:39:34
08.05.2020 19:11 # 5
baybaba
Students may have an exam question about what you have written above in the YGS exam. Smile
08.05.2020 19:11 # 6
Faruk
[QUOTE = transform609] Greetings everyone, friends ... I have a malfunction that I think is chronic for the 307s.
I suffer exactly the same problem.
The last 2 years ago, the industry side, the driver's side had cut off the control for a short time when I changed the control, but now only the driver's side opens to me to press 8-10 times, the others open according to his head, etc.
so the problem is probably the driver's side control.
I opened it and cleaned it, it got a little better then the same.
I don't know exactly what to do.
I also have a problem with this problem because a friend said that the pads on the pad are plastic, the water is making moisture, there is conductive paint, I couldn't do it yet.
I am waiting so problematic problematic.
I wish we could find the solution
08.05.2020 19:11 # 7
emrercmrt
Good day, I think the problem is that the cables come from the arm on the side of the driver. There was a problem like this. I had the wd40 product on both male and female sockets.
08.05.2020 19:11 # 8
themurat54
[QUOTE = baybaba] What you wrote above might have students ask exam questions to understand what they read in YGS exam Smile
I was among the 7 options, which one is the answer: D: D: D
Joking, let's solve your problem, you will have a lot of problems in my Peugeot!
themurat54 2015-03-25 16:58:08
08.05.2020 19:11 # 9
Canberk35
[QUOTE = Faruk] [QUOTE = transform609] Greetings to everyone, friends .. I have a malfunction that I think is chronic for the 307s.
I become that friend. Smile There is absolutely no problem in the circuit or sockets of the controller or anything else. Don't worry about it. If you buy a new one, it will probably become the same in 1-2 years. The supplier industry is less durable. This is because the pads that complete the circuit in the control are stuck. The most useful solution is to paint those pads with conductive paint. I have to open the remote and clean it with pure alcohol for 2-3 weeks.
I contacted a friend who painted his controller pads with silver conductive paint, not carbon, on another site. He said that there was deterioration even after 7-8 months with silver paint. So I gave up buying paint. Silver paint is already around 50 TL. After talking to a friend, I thought, "If he will manage for 7-8 months, he will manage the sub-industry so much. I will renew the control as an image." But I haven't done that either. :)
I have not tried different methods since I have not completely given up the control. There are ideas like sticking aluminum foil or a different conductor on the pads. If there are friends who give up their command, they can try.
In addition, it is very simple to disassemble the controller. There is already a screw. After removing it, there are two sockets on the bottom. By removing your nails, you remove the sockets. The control is completely free. The middle part with the circuit sits again with plastic nails. When you get rid of them, the control is fully unlocked. If you clean the circuit and pads with alcohol, it will last about 1 month. If you say I repeat every month, the cost is close to zero. Smile
08.05.2020 19:11 # 10
transform609
Dear friends, thank you very much for your interest ... I went to the past industry, I showed it to a glazier master, thanks to the problem of getting up and down on the windshield with a special spray. Also, he did not receive a penny in spraying, my dear Corlu trades :)
As if resolved quickly :)
08.05.2020 19:11 # 11
burglar08
Don't hurry, let it be 3-5 days later :)) it's only in the left two windows. I bought a new remote and it was the same after 1 week. No problem closing the key but me too. I will try to say what your friend said on the halter.
08.05.2020 19:11 # 12
Canberk35
[QUOTE = transform609] Dear friends, thank you very much for your interest ... I went to the past industry, showed it to a glazier master, thanks to the problem of getting up and down the windshield with a special spray. don't give me money, "he also said, he didn't take a penny in spraying, my dear Corlu trades :)
If I remember correctly, the remote in the driver's section has two sockets, black and gray. I remember that when the remote is in the mounted position, it hangs black front and gray back. I guess, if it is wrongly installed, the backs open and the backs open. (Actually, if the operating logic of these sockets is like this, you have to try. My rear windows are OK. LOL )
I hope it becomes a permanent solution. It seemed to me rather like cleaning with pure alcohol. I hope not. If it breaks again, please inform us. Even if it doesn't repeat, inform it. Let's take that spray too. Smile
08.05.2020 19:11 # 13
transform609
Thank you very much, the situation. Absolutely.
brother, it was a light intense spray, the paper was removed from the box, maybe the man who made it special is here, the chemical factory is full here.
08.05.2020 19:11 # 14
Faruk
My teacher got up and down the problem from the front two windows.
How bored was your master?
08.05.2020 19:11 # 15
Faruk
[QUOTE = Canberk35] [QUOTE = Farouk] [QUOTE = transform609]
Smile
I haven't been in the paint business yet.
yesterday I dismantled the remote, opened it and cleaned it, then put it on, it was like a monster. LOL
I do not know if there is a problem. There is a light on the button that prevents the rear windows from opening, but it did not work, then I tried to open it again, I probably did something missing.
08.05.2020 19:11 # 16
transform609
My teacher Faruk, as I wrote above, there was no paper on the box.
08.05.2020 19:11 # 17
xmen
In my driver's window control, it was only a problem when the driver's glass was lowered and raised ... I did the cleaning process .. it did not improve ... eventually it was broken to play LOL I went, I got zero, I took it off, I put it on myself, there is no problem for now, thank goodness ...
08.05.2020 19:11 # 18
transform609
I hope xmen is the definitive solution.
08.05.2020 19:11 # 19
Faruk
[QUOTE = transform609] My teacher, Faruk, as I wrote above, there was no paper on the box.
then our luck is hard because the service couldn't find a solution Smile
08.05.2020 19:11 # 20
Faruk
The handle of the driver, which I opened and cleaned in the friends, was thoroughly obsessed.
Cam lift lowering is smooth, but when you press the lift in the middle of the two windshields, the lowering continues.
so it's not the control, it's the problem.
The solution will be solved with a spray like that of our transform609 friend, but we don't have it either.
Page : / 2
