Windscreen resistance
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 3008 (2016-)
08.05.2020 21:28 # 1
ARSLANIM
Good day guys, I just joined you. I am using the 2018 model 3008, when I run the windscreen resistance under the piano keys to melt the ice formed on the windscreen in the morning, the air conditioner is activated. Doesn't it have to work like a resistance on the rear window. I am waiting for your support if there is anyone who knows about the subject.
08.05.2020 21:28 # 2
First of all, welcome to us. Because the windshield does not have any resistors on the windshield, the air conditioner is activated to dissolve the ice, so that the hot air will come immediately, or it will not be dissolved until the engine warms up. A normal situation is the same for all new generation vehicles.
08.05.2020 21:28 # 3
ARSLANIM
thank you, I knew the air conditioner was useful for demisting in this regard, but I was expecting a function like the resistance on the rear window for the glass that freezes from the outside. Thank you for your support.
08.05.2020 21:28 # 4
You are welcome, unfortunately, it will not be from the front resiz. You can use the air conditioner in the same way as in offices and at home, both for cooling and heating.
16.03.2021 19:10 # 5
Rustem Turan
If you pour cologne or glass water directly on the glass from outside, it will melt the ice very quickly.
09.07.2021 11:45 # 6
zeytinkoy
There are vehicles with a resistor on the windshield. It was in many models of Ford before. Of course, the windshield heater does not have lines like the rear window heater.
