Windscreen lath
08.05.2020 21:17 # 1
Servet34
Hello there! Where can I find friends 307 windshield bottom grille Servet34 2019-09-22 11:07:59
08.05.2020 21:17 # 2
EmSul
Is your vehicle manual or automatic?
Did you connect the computer with the abs light on?
08.05.2020 21:17 # 3
Servet34
manual yes connected when lit
08.05.2020 21:17 # 4
EmSul
I think it would be a cable from the abs brain to the vehicle brain. If there is an abs sensor or a ball, it should also be a problem in the abs brain, of course.
08.05.2020 21:17 # 5
samet2461
God help you. I had the same fault in my 307 vehicles 3 years ago. I worked for 3 years. I bought zero brains for 2.500tl and completely changed the installation. I still couldn't solve it at 100%. He reminded himself once a year saying that I am here.
With the ABS fault, braking fault inscriptions, the handbrake and the abs light were on and the stop was flashing. The mileage indicator would go to zero as soon as it worked. I would turn off the ignition and turn it on. "Intermittent malfunction general CAN malfunction" was in my error.
08.05.2020 21:17 # 6
Servet34
God bless the masters checked the whole installation, now the fuse box appeared in the trash, the box under the engine hood has been replaced by something that has been repaired before, I hope it is being tested, I hope it has been resolved.
08.05.2020 21:17 # 7
KILIC
Hopefully it has been resolved. Electronic malfunctions are unfortunately the most annoying malfunctions. find a problem, solve another problem.
08.05.2020 21:17 # 8
Servet34
the problem is solved, thank goodness the fuse box was caused LOL
08.05.2020 21:17 # 9
samet2461
[QUOTE = Wealth34] problem solved, thank goodness it was caused by the fuse box LOL [/ QUOTE]
Hopefully my brother has been solved. I was so happy that it was repeated on a black night Dead
