windscreen |
| • Homepage » PEUGEOT MODIFIED PLATFORM » How To | |
| 08.05.2020 17:43 | # 1 |
I noticed when washing the car & nbsp; I thought that if I peel off that glass completely, now I would stick it with double-sided tape but whatever the bottom adhesive is to the ground, which is firmly attached to the floor, but to the ground, but to the ground, I need to remove the complete adhesive. Do you have a practical advice to disassemble it? For example, when you wash it, remove it & nbsp; or wet and soften it. Like ... ?? Bidet ordinary ordinary sided tape would work or should I get something else ??
| 08.05.2020 17:43 | # 2 |
307bursa thanks < br> I am sure that it will deal with it, other than wetting it, what can we make our job easier with? anyone have any idea
| 08.05.2020 17:43 | # 3 |
complete disassembly just disassemble the shield part a bit then paste partial tape torture completely disassemble ...
| 08.05.2020 17:43 | # 4 |
This makes sense, I forced it a little bit because it would be quite tortured because I would lift it all by myself. Well, as I said, is there any auxiliary substance in disassembling it out of the water |
