windows do not close from the remote
08.05.2020 18:58 # 1
seydisehirli
Hello friends, as of yesterday, my 307 xt vehicle would open the locked windows with a long press on the lock on the door, but now it does not close, it also does not turn on the ceiling lamp when the door is opened, and it starts to go out without waiting for your help.
08.05.2020 18:58 # 2
monalos
I do not have any information about your problem, but I chose to write here instead of opening a topic again. I have 206 206 xt vehicle.
08.05.2020 18:58 # 3
muro_60
If the ignition of the vehicle does not hurt, press and hold the shutter button for 15 seconds.
08.05.2020 18:58 # 4
seydisehirli
bro, now I have it made to code, open the doors from the remote control, then lock the door with the contact, then hold the door in the same direction for 3-5 seconds, then lock the door, then do the same operation to open the door, open this process 3 times and lock it in 3 times, then download the glass and click on the contact long press the lock knob windows are closing try
08.05.2020 18:58 # 5
monalos
No, I haven't tried it, no, not in my car Or I can not do it, meanwhile, the car control was canceled after doing these operations :) It was recovered in 1 minute, previously the control was taking from the 2nd floor, now it does not go without going to the battery.
08.05.2020 18:58 # 6
seydisehirli
I don't know if my brother was misled, I apologized to help
08.05.2020 18:58 # 7
BEYATAYA
battery was weakened two months ago my 307 xt grandfather was the same.
08.05.2020 18:58 # 8
hatayli
Friends, I press the left left cam button on my vehicle. Normally, I download the mosque, but it does not do the lifting process, it is downloading again. What could be the problem
08.05.2020 18:58 # 9
monalos
[QUOTE = seydişehirli] I don't know if my brother was misled, I apologized for helping
No SISTER It is not an annual situation, it was already there :) You already wanted to help Saol,
08.05.2020 18:58 # 10
monalos
[QUOTE = erroneous] Friends on my vehicle, I press the left left cam button, the mosque is downloading normally, but it does not do the lifting, it is downloading again. What could be the problem [/ QUOTE]
It may be from the button Or there is something in the cables show to the electrician
08.05.2020 18:58 # 11
okaNStarss
If you do not lift the engine, if it does not lift it, it may be from the glass wicks, if it does not lift the coals of the glass engine may be troubled.
08.05.2020 18:58 # 12
hatayli
[QUOTE = okaNStarss] [QUOTE = erroneous] Friends on my vehicle press the left left button of the glass, it normally lowers the mosque but does not do the lifting process again. What could be the problem [/ QUOTE]
[/ QUOTE] no strain. it just knocks the glass down, not back. lifts with the module only
08.05.2020 18:58 # 13
ismailkaya
I think the controller is running out of battery
Hataylı: I guess you will open up and clean the inside of the dust.
08.05.2020 18:58 # 14
hatayli
[QUOTE = ismailkaya] I think the controller is running out of battery
[/ QUOTE] I'll try it in the morning.
08.05.2020 18:58 # 15
muro_60
[QUOTE = erroneous] Friends on my vehicle, I press the left left cam button, the mosque is downloading normally, but it does not do the lifting, it is downloading again. What could be the problem [/ QUOTE] insert the glass knob and clean it with cologne
08.05.2020 18:58 # 16
seydisehirli
cd cahanger not working can cause lights blinking?
