Wind of Separation .....
08.05.2020 16:51 # 1
ibrahim. kut 2014-05-10 02:17:58
08.05.2020 16:51 # 2
metin
Are you sure it is 700 liters? Normally, I don't know how many liters, but they said the price had increased from 40 TL to 80 TL last year. I think the price is normal.
When the air conditioner starts, it forces the car a little bit because it gets power from the engine, it increases in fuel.
08.05.2020 16:51 # 3
He burned 200 cents per km, 300 will not be in any case twill
08.05.2020 16:51 # 4
metin
[QUOTE = ibrahim.kut] He was burning 200 cents per km, no 300 will happen anyway, right now [/ QUOTE]
not so much, the engine gets a little hard because it gets power from the engine, it is in the traction you feel a slight fall anyway. When you think about traction, you will push the gas a little bit more, fuel will increase.
08.05.2020 16:51 # 5
Alicilik
[QUOTE = text] [QUOTE = ibrahim.kut] burned 200 cents per km, no 300 will happen anyway, twill [/ QUOTE]
not so much, because it gets power from the engine the engine has a little difficulty, you feel a slight drop in traction. When the traction is thought, you will push the gas a little more, the fuel will increase and I press it a little more (:
As the master says, the performance decreases because you get power from your engine and if you try to close this performance gap by loading it on the gas The air-conditioned car burns a lot "Big
08.05.2020 16:51 # 6
toga406
I do not know what 700 liters of luck is possible, do you know how many cars are paid for gas?
does not even lose weight.
08.05.2020 16:51 # 7
sosyete_60
They had 700 gr gas, not 700 lt. Also they had to print 790 gr.
