Will Tire Size be reflected in Speed? |
| • Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » All Questions About Your Vehicle | |
| 08.05.2020 20:37 | # 1 |
| 08.05.2020 20:37 | # 2 |
of course there is a difference, but this difference is evident if measured by navigation. Because km is measuring the rotational speed of the wheel, not its diameter. For example, when the original size turns, let's say the vehicle moves 1 meter but 0.9 meters in your size. This is not understood on the screen, but when you turn on the navigation from the phone, your car shows 100 while the navigation shows 95 or something, or if the larger size is attached, your car can show 105 km while the car shows 100. My 206 diesel car's gearbox and the pressure pad are now at the same speed close to 2200 rpm when traveling with 90 at 200 rpm. It can go, it bothers me, but I don't wear it anymore
| 08.05.2020 20:37 | # 3 |
sonerkyl |
of course, it does. In addition, these tire sizes need to be introduced to the vehicle. Due to km event. Of course, as our friend said, testing the most beautiful navi. For example, while my vehicle is driving at 90 km with 308 km, my vehicle shows my GPS speed at 87. There will be 3-4 km tolerance difference. valid for all vehicles.
| 08.05.2020 20:37 | # 4 |
maximusti |
when I go with 100 in my car it shows 95 blah Originally there are 14 "wheels, I installed 16" wheels on the vehicle.
| 08.05.2020 20:37 | # 5 |
[QUOTE = sonerkyl] is of course far. In addition, these tire sizes need to be introduced to the vehicle. Due to km event. Of course, as our friend said, testing the most beautiful navi. For example, while my vehicle is driving at 90 km with 308 km, my vehicle shows my GPS speed at 87. There will be 3-4 km tolerance difference. valid for all vehicles. [/ QUOTE] Soner additional let me note that. When you turn on the cruise control in 308, there is a full 4km difference between the indicator and CC. This is not due to the deliberately adjusted tire size. When it comes to your friend's question, of course it does. If the tire diameter changes, the distance the tire takes in one turn also changes. They do not advise us to wear very large rubber sizes, in fact, it is useful to install the diameters recommended by more standard companies. |
| 08.05.2020 20:37 | # 6 |
Oktkor |
Sir, your tire distance falls a little. If it shows 100, you're actually going with 98. Maybe 98.5. |
| 08.05.2020 20:37 | # 7 |
Sir, my rim is the same 45 on the 16 inch door, the same size is just 195. 205 says it should be. So would I have a chance to correct this 3-4 km difference? Does anyone have any settings on the display?
| 08.05.2020 20:37 | # 8 |
Oktkor |
[QUOTE = SelimK] Sir, my rim is changing from the same 45 on the 16 inch door to the same size, only 195. 205 says it should be. So would I have a chance to correct this 3-4 km difference? Does anyone have any settings on the display? [/ QUOTE] I will not know that much. There is definitely a setting. Everything but the Turkey sent thicker cheek cars for the road conditions. I think the brain can be intervened, but you have a very low difference. It is not even worth worrying about. For my winter tires 55 shame 60 eg. There is almost no difference. yours is more suitable than mine. |
| 08.05.2020 20:37 | # 9 |
ggitaristt |
My friend cars dashboard, ABS speed sensors and gearbox gear ratios are standard but not the same .. This can make a difference in the speed of the car or even in the same brand model vehicle .. But the size of the tire you wear does not change the speed ratios on the dashboard. The speed you traveled varies, but not in the car's dials. |
| 08.05.2020 20:37 | # 10 |
Hello benign tire size is important in fuel I have 407 previous tires 205/55 current tires 215/65 10 km of fuel dropped in km As the tire diameter grows, it drops in km Most people say that they tire the car. No relation on the contrary, it makes the difference |
| 08.05.2020 20:37 | # 11 |
Oktkor |
[QUOTE = Habip slider] Hello benign tire size is important in fuel I have 407 previous tires 205/55 current tires 215/65 10 km of fuel dropped in km As the tire diameter grows, it drops in km Most people say that they tire the car. No relation on the contrary, it makes the difference of take-off road [/ QUOTE] 10 cents per km? |
| 08.05.2020 20:37 | # 12 |
Difference from other diameters compared to 205/45 / r16. The final percentage shows the difference. With 195/45, it means that the dial will show a speed of 100km while it will be 98.3km speed. Up to 3% difference is said to be acceptable. 195 / 45R16 22.9x7.7r16 22.9 "-1.7% 205 / 45R16 23.3x8.1r16 23.3 "Equal 135 / 70R16 23.4x5.3r16 23.4 "+ 0.4% 215 / 45R16 23.6x8.5r16 23.6 "+ 1.3% 195 / 50R16 23.7x7.7r16 23.7 "+ 1.7% 185 / 55R16 24.0x7.3r16 24.0 "+ 3.0% 225 / 45R16 24.0x8.9r16 24.0 "+ 3.0% |
| 08.05.2020 20:37 | # 13 |
[QUOTE = Habip slider] Hello benign tire size is important in fuel I have 407 previous tires 205/55 current tires 215/65 10 km of fuel dropped in km As the tire diameter grows, it drops in km Most people say that they tire the car. No relation on the contrary, it makes the difference of take-off road [/ QUOTE] Dude you are expanding the base and enlarging the diameter of the tire by 9%, no fuel savings. When you measure it, can you renew the 205's for the winter or something?
| 08.05.2020 20:37 | # 14 |
It was old wintry, but there were no teeth, the road you make becomes shorter as the tire diameter increases
| 08.05.2020 20:37 | # 15 |
Makes 128 smileys on 3000 tires in old tire 3000 in the new tire Makes 135 smileys Buddha affects fuel |
| 08.05.2020 20:37 | # 16 |
Measuring with navigation is a good idea bidet I experience
| 08.05.2020 20:37 | # 17 |
In the same conditions, I made a measurement in the dish with navigation, the speed of the vehicle was 3-4 km more than the screen, so 100 on the dial showed navigation as 103. I came to Istanbul later in the same day, this time the dial was 100, while the navigation showed 97.
| 08.05.2020 20:37 | # 18 |
I tested the vehicle again. While showing 100 from navigation, the tachometer of my vehicle at 105 is at 3000. While the actual speed should be 90 at 2500 rpm, it shows 87 on the needle, and it shows around 84 when I look at the car's navigation. I don't understand, it's gone. I wonder if my car is losing performance. As I said, I have to do 2600 dd to catch 90 in the needle, as I said, I need 2700 or so, it seems to have an average of 200 dd loss ....
