Will the sensors not work when the 307 windshield is replaced?
08.05.2020 14:51 # 1
ozgurkso
The windshield of my 307 car needs to be changed. The original is around 600 and I don't want to give that much money. The local 200 TL alone said that the rain and headlight sensor might not work. I'm going to give 600 TL for the sensors to work. I'm waiting for your urgent help, friends.
08.05.2020 14:51 # 2
My friend has no relation to the glass with the headlight sensor. sir..
08.05.2020 14:51 # 3
GokhaN
[QUOTE = ozgurkso]
you need to find quality glass for the sensors to work. They do not remove mold on domestic glasses and do not deal with sensors. An important problem awaiting the owners of the 307 is the replacement of the sensor windscreen. They attract very high prices in services. They may not want to pay these prices in car insurance.
08.05.2020 14:51 # 4
ozgurkso
[QUOTE = laedri] My friend has nothing to do with the glass of the headlight sensor ... The headlight sensor works inside and when it detects the darkness ,, The rain sensor is also integrated with the glass ... The master said to me that I could not place a rain sensor on the new glass ... Ask that master to do other places .. [/ QUOTE]
I asked a lot of glass makers, they do not guarantee the sensors, but if the headlight sensor will work, only 400 TL difference is more for the rain sensor.
08.05.2020 14:51 # 5
Psh
I don't have a rain sensor, but they wanted 650 on the original glass.
08.05.2020 14:51 # 6
ozgurkso
I used the 190 tlye local glass, it works on the sensors.
08.05.2020 14:51 # 7
yzt06
No they did not lie ... the sensors were not working properly when I bought my car. For example, I was constantly switching on the headlights ... I changed the windshield .. There was a local brand of olimpia brand .. I had the original glass ..
08.05.2020 14:51 # 8
yilmaz34
I had the same trouble, I was wearing non-original glass from the switch, olympic brand headlight sensor was working, but the rain sensor was not working
I even got it to the service, I said they need to change the glass, they did not change the glass, then I did not change it, then I did not change it, then I saw it, and I saw it with the brand of glass, and finally, I was using a gel in contact with the glass, the problem was resolved.
08.05.2020 14:51 # 9
ozgurkso
or I couldn't find this gel. The rain sensor works a bit irregularly. How do we get this gel? Whatever useful is it. If we have a rain sensor, do we have the opportunity to reduce the interval?
08.05.2020 14:51 # 10
serverumut
Hello there. I had 206 pejoma sub-industry windshield installed and the rain & headlight sensor does not work properly. The headlight is always on, the rain sensor is working at a single speed and it does not work in the rain ... They told me that I should wear glass with filter ... I think to change this year, if I find a cheap way from the insurance, I will get them guaranteed to work ...
08.05.2020 14:51 # 11
metin
[QUOTE = ozgurkso] I did not find this gel, the rain sensor is working a bit irregularly. What is the use of this gel?
The light intensity of the headlight sensor is adjusted but I guess I do not know if there is a chance to adjust it because the rain sensor adjusts according to the intensity of the rain, I suppose not. My vehicle also cracked the windshield, I could not change it in the service because it is LPG, the three in Kadıköy Söğütlüçeşme went to the auto glass. If there is no contact with the bidders authorized service, you can find out if there is any.
08.05.2020 14:51 # 12
The wind sensor does not pose any problems to the rain sensor, short and clear :)
08.05.2020 14:51 # 13
gozem
On my 307th the windshield was changed in time and the sensors are not working properly.
What do you think can be the most effective solution without replacing the windshield ..?
08.05.2020 14:51 # 14
hasancalp
Doesn't Work Properly ... I would definitely not recommend. The most logical one is to make a car insurance from a suitable place In any case, the motor vehicle gives the right to change glass once a year ... You can never get efficiency from domestic windows. I think there is a difference in color, it does not work on glasses because of it ... Easy to come ...
08.05.2020 14:51 # 15
cesar67
I changed it last week, olimpia cam works fine both of them :)
08.05.2020 14:51 # 16
semsword
Greetings. The sensor of my (2000 model 206 1.6XT) car had been blinking for years but it was not working. We even bought it in February 2005. This time I stubbornly run it. I removed it, I saw that there is no sensor gel in one of the two sensors. Even if the other gel (or pad is whatever) is not fully seated
When I searched a little online, I found out that the rain sensor works with both eyes. also that these sensors work according to the refraction of light. So these sensor gels (or pads) do not work at all or well if they do not fill the sensor between the sensor and the glass completely without the smallest air bubbles, fingerprints, dust, dirt. The glassworkers who do this work are not as meticulous as they should, because as a result of my research, "your car's sensor is broken" or "this sensor is not suitable for the original glass", "it does not work when the original is not attached". I understood that they were defending the citizen from their heads.
I searched the sensor gel or pad on the internet so I could do it myself and found the SensorTack product. Unfortunately, the men were in Germany. SAYAN OTOMOTİV SAN.VE TİC.LTD.ŞTİ is also in Kartal Oto Sanayi (accessory), where they send products in Istanbul. (i.e. far from me) ... But I have learned from websites (PMA TOOLS) that there are three different sensor types and solutions accordingly. It is also just that the sensor pad is suitable for my car's sensor. Because;
-SensorTack1: Transparent as glass but liquid as water (freezes at 15-20min) gel (i.e. it flows from the edge of my sensor)
-SensorTack2: It has a matte transparency. This is a liquid gel (freezing in 15-20 minutes). (Peugeot 307's should be that)
-SensorTack3: Transparent as glass, thick, flexible band. I asked every auto glazier that I saw that something like this is in certain glass shops. Finally, I found a similar product in the auto glass shop located on the left above the hill that goes from Davutpaşa to the Ülker factory (or in the middle of the lights when you go straight next to Ford in cevizlibag).
I cut it exactly according to the pad on the vehicle, stick it on both eyes and the rain sensor now works great.
However, there are many points to be considered:
1- When cutting and cutting the Sensor Pad (gel or tape), it should never be touched. As soon as it touches, a fingerprint is formed and the pad becomes distorted. To do this, remove the tape and open the adhesive on the other surface with a clean non-stick paper, etc. something should be cut and cut and held only from paper (glassmakers cut with palm).
2-When cutting the sensor pad, it should use a scissors that cut very well.
The face of the 3-sensor and glass must be very clean. no cotton / paper residue, etc.
4-It should be cut completely according to its slot and should not be lengthened while pasting
5-In no way should ped.e be used
6-While mounting the sensor, it should be placed in a single alignment and well aligned.
Note: The glass of my car is also domestic glass.
I solved the event. I said let me share. Hopefully it will be useful for what I wrote.
semsword 2011-06-10 21:35:59
08.05.2020 14:51 # 17
semsword
http://www.pma-tools.net/tr/sensortack.html
08.05.2020 14:51 # 18
semsword
It was the first time I saw rain today since I repaired the rain sensor, the performance was great Thumbs Up .
08.05.2020 14:51 # 19
ose
[QUOTE = semsword] Greetings. The sensor of my (2000 model 206 1.6XT) car had been blinking for years but it was not working. We even bought it in February 2005. This time I stubbornly run it. I removed it, I saw that there is no sensor gel in one of the two sensors. Even if the other gel (or pad is whatever) is not fully seated
[/ QUOTE] halal you have completely done the job. AlkışAlkış
08.05.2020 14:51 # 20
tigerland
No picture, the glass has changed in me, the sensor is not working. but the sensor is active when viewed from the outside, the light is on, is the sensor there when viewed from the outside under the mirror?
Page : / 3
