Will the different brightness in the headlights improve?
08.05.2020 20:16 # 1
ben_erhan
Hello friends.
My vehicle is 307 xt 1.6. 2004.
The right headlight is brighter but the left headlight is dimmer. I think the mirror inside the headlight is gone. Can I fix this .. if I get out, it will be so. There will be a difference in brightness again. If I buy zero, I will get brighter than I bought .. 350tl .. couple 700 .. a world of money will go to a job that is not worth .. Can I open the headlight. Will I find a solution if I open it? Do you have information?
Thanks
08.05.2020 20:16 # 2
maximusti
you can have headlight cleaning, 100% solution.
In addition, if you shoot a film on the headlight, if you make a movie, it does not show much difference.
I think the pair is not worth 700 TL as you said, but maybe you can find a pair of headlights.
08.05.2020 20:16 # 3
ben_erhan
Thank you for the answer .. I found the 2009 model deindi. 2004 model is my vehicle. Is there a difference in the headlights of make-up?
08.05.2020 20:16 # 4
ggitaristt
The 307 headlamp with make-up does not fit the normal 307. Don't let the bulbs be different from each other?
08.05.2020 20:16 # 5
BLACK LION
I recommend that you have the headlights adjusted by the height settings. If the lighting angle of the headlight you are replacing is different, it may also feel brighter than one above and one below.
If you open the headlight with the difference in exterior appearance and apply the headlight dimming of the parts outside the headlight mirror, it will look more elegant and the difference will disappear.
08.05.2020 20:16 # 6
ben_erhan
Is the headlight easy to open?
There are no preferences to buy headlights. So I have to solve this event somehow.
The two I don't understand are original headlights. Change never happened. The date labels are on it. How can someone be like older.
