Will it be like this in 2008?
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 2008
08.05.2020 18:41 # 1
acemi pecocu
Selam aleykum I just bought 2008 is a very nice ride, a delightful disadvantage to go back uphill, not to go past the gear, a slowdown can't go past the service in question, I would like to consult the subject here, if there are people who use it, I would appreciate it.
08.05.2020 18:41 # 2
Mesut48
Good luck, use it without any trouble, we are waiting for your photos :)
If there is support for departure, it will move a little late as soon as you stop.
08.05.2020 18:41 # 3
ahmed206
Hello, good luck, can you tell us more about the slope?
Or, there is no guarantee, it is better to go to the service.
08.05.2020 18:41 # 4
acemi pecocu
[QUOTE = Mesut48] Good luck, use it without any trouble, we look forward to your photos :)
[/ QUOTE] If I could manage to take a photo, I'll throw it
08.05.2020 18:41 # 5
acemi pecocu
There is a hill holder but I wonder if there is a problem caused by it and the engine has not been turned on.
08.05.2020 18:41 # 6
Serkan
The vehicle you use is not like a semi-automatic robotized gearbox, fully automatic, unfortunately, use a little speed on the slopes, when you stop, the hill start is already activated. As you get used to it, the person gets a little bit obscured when it goes through full automatic.
Edit: I felt the need to explain :)
There is a clutch in your vehicle's gearbox and there is a robot that presses the clutch and shifts it, as you press the throttle, the robot presses the clutch, raises the gear and releases the clutch.If the speed is low while the hill is coming up, the vehicle may come to a halt in 1-2 passes, even if it is too low, it may come to a halt point. It is not a problem for these transmissions to work. For this reason, you can minimize clutter by providing a high speed gear shift by pressing the throttle a bit at the exits. Since there is no clutch event in full automatic, direct gear shift is provided and there is no accumulation.
Serkan 2014-07-11 01:31:09
08.05.2020 18:41 # 7
Aziz
Serkan brother, you have finished us, I'm crying, I'm crying with pride, my god: D: D
08.05.2020 18:41 # 8
acemi pecocu
Thank you, manager tşkler Aziz representative, it is good to cry, always cry Stern Smile
