|   | Will 177/55/14 tires fit 195/65/15 wheels? |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Wheel Tire Selection | |
| 08.05.2020 14:52 | # 1 |
|  halil_37 | |
| 177/55/14 >>> 195/65/15 ??? | |
| 08.05.2020 14:52 | # 2 |
|  arifziyaar | |
do you think: P
| 08.05.2020 14:52 | # 3 |
|  H-a-d-i | |
[QUOTE = arifziyaar] do you think: P [/ QUOTE]  I agree with this question but I answer it. This is impossible because the numbers 14 and 15 at the end are not the same in both sizes. | |
| 08.05.2020 14:52 | # 4 |
|  halil_37 | |
[QUOTE = Come on] [QUOTE = arifziyaar] do you think: P [/ QUOTE]  I agree with this question but I answer it. This is impossible because the numbers 14 and 15 at the end are not the same in both sizes. [/ QUOTE] It would not be at first, but a post that I saw in the forums of the pride would confuse my mind, if the man says his width is close to one another, he could follow one size rim ... this would confuse my mind ... but it would not be anyway: D thank you gone, rims: D thank you for answering. ... | |
| 08.05.2020 14:52 | # 5 |
|  Onur | |
it is wider than width 175-185 is 14 inches by 15 inches does not fit
| 08.05.2020 14:52 | # 6 |
|  Guests | |
Can I wear size 36 wearing 42 shoes
| 08.05.2020 14:52 | # 7 |
|  deniz_206 | |
no sooner
| 08.05.2020 14:52 | # 8 |
|  voodoo | |
You are not my brother;)
| 08.05.2020 14:52 | # 9 |
|  halil_37 | |
thank you friends :) In this way, I did not have a question mark in my mind :)
| 08.05.2020 14:52 | # 10 |
|  degisik | |
friends, I was a new member of the bottle, I got the 99 model peugeot 206 1.4 75 hp I got the rim, the second hand, I did not look at the car, the warning is the original gti rim, the wind is gull, it would be straight, I looked at the tire in the paint today, I would be supposed to be in the tire 55 55 15 lassa Please  | |
| 08.05.2020 14:52 | # 11 |
|  BULUT06 | |
4x108 206's the original cc wheel as far as I understand it is not a problem
| 08.05.2020 14:52 | # 12 |
|  remo52 | |
Hi  STARMAXX 185/55 / R15 82H ULTRASPORT 2015 I am thinking of buying a tire in these sizes. Will my car make rubbing or something with 2000 model 206 and 15 inch viper wheels?  | |
| 08.05.2020 14:52 | # 13 |
|  samet206 | |
Can the mouth of the 5-liter demijohn be closed with the lid of the 2.5-liter pet bottle. This is the calculation :) If the 185.55/15 tire does not have any friction in 206, the ET value of the rim is not important, the tire size is very suitable. and peugeot generally uses 4x108, but it is worth noting that especially the ford indexed wheels create incompatibility with peugeots.Peugeot produced is compatible with all kinds.  | |
| 08.05.2020 14:52 | # 14 |
|  madblueblacksea | |
[QUOTE = remo52] Hi  STARMAXX 185/55 / R15 82H ULTRASPORT 2015 I am thinking of buying a tire in these sizes. Will my car make rubbing or something with 2000 model 206 and 15 inch viper wheels? [/ QUOTE]  The outer diameter of the tires is the same as the original tire (175/65/14 2mm smaller) The hub depth of the rim you should look at  | |
