Why the steering wheel hardens over time
08.05.2020 15:47 # 1
cetin
It caught my attention that the steering wheel of my car started to harden over time.3 months ago, when I changed the rear tires, it became soft, great but now I realize that it has gotten pretty hard . What should I do to soften it ? Ouch the pugt 2011-07-08 17:48:20
08.05.2020 15:47 # 2
First of all, you should check the level of the steering fluid.
08.05.2020 15:47 # 3
cetin
how ?
08.05.2020 15:47 # 4
metin
[QUOTE = hard] how? [/ QUOTE]
opening the cover (:
08.05.2020 15:47 # 5
What you are looking for is the black cap and red text on the cap, as in the picture below. This picture has been taken from 206 but it may change its place in your vehicle but the shape of the cover is the same. Take it out by rotating and you will see that there is a bar attached to the lid. It is stated where it should be in the cubicle. If less, you need to complete it.
Koliva 2011-07-08 17:37:30
08.05.2020 15:47 # 6
Saleeh
[QUOTE = text] How is [QUOTE = hard]? [/ QUOTE]
Star
08.05.2020 15:47 # 7
Check the oil level, our friends say it right. The level you looked at is normal. There is a shortage in osman steering hydraulic pump.
08.05.2020 15:47 # 8
metin
how many liters of oil this steering takes. While I was going to the sea, I had a humming problem caused by the steering wheel, then I bought the original steering oil in the service in the sea but I did not use it. If it is easy to change, I think I will put it on the steering wheel. we renewed the oil.
08.05.2020 15:47 # 9
[QUOTE = text] brother, how many liters of oil this steering takes. While I was going to the sea, I had a humming problem caused by the steering wheel, then I bought the original steering oil in the service in the sea but I did not use it. If it is easy to change, I think I will put it on the steering wheel. we renewed the oil. [/ QUOTE]
In our model, 307 1.6 gasoline manual ones are 2 liters, automatic ones are 4 liters.
You can check the page of Total:
Application Recommendation Capacity (ltr)
Engine (P) QUARTZ 9000 5W40 (a, c) 3.3
Manual Transmission TRANSMISSION SYN FE 75W90 2.0
Automatic Transmission (b) 4.0
Differential From gearbox
coolant Refer to Owners Manual 6.2
Brake Fluid HBF 4
Electro-hydraulic steering FLUIDE LDS
Wheel bearings MULTIS EP 2
08.05.2020 15:47 # 10
cetin
[QUOTE = koliva] What you are looking for is the black cap and red text on the cap, as in the picture below. This picture has been taken from 206 but it may change its place in your vehicle but the shape of the cover is the same. Take it out by rotating and you will see that there is a bar attached to the lid. It is stated where it should be in the cubicle. If less, you need to complete it.
thank you so much....
08.05.2020 15:47 # 11
maestro
I know that the steering wheels harden even when the ends of the swing bars deform over time
08.05.2020 15:47 # 12
metin
[QUOTE = koliva] [QUOTE = text] big brother how many liters of steering oil it takes. While I was going to the sea, I had a humming problem caused by the steering wheel, then I bought the original steering oil in the service in the sea but I did not use it. If it is easy to change, I think I will put it on the steering wheel. we renewed the oil. [/ QUOTE]
Brake Fluid HBF 4
I think you talked about the gearbox I am talking about the steering wheel
08.05.2020 15:47 # 13
metin
[QUOTE = maestro] I know that the steering rods become stiff when the ends of the swing bars deform over time [/ QUOTE]
how am i hearing for the first time
08.05.2020 15:47 # 14
maestro
the ends of the balls wear out over time my steering wheel had also hardness when it was changed.
08.05.2020 15:47 # 15
Hard steering is good, you feel the weight of the car .. It doesn't feel like you're knocking on the road ...
08.05.2020 15:47 # 16
I think the text should be about 1 liter of steering wheel ... But 307's hydrology is different from others. The ones on us are the same as the automatic transmission oil, but there is a special oil in the leaking steering wheel total brand ...
08.05.2020 15:47 # 17
Sorry about the text, I really looked wrong.
I replaced it, I bought it completely and I bought it 1 liter. It doesn't even take all 1 liter.
08.05.2020 15:47 # 18
metin
[QUOTE = cecol of]
I bought the original oil 1 liter or even Murat brother and made him look at the part number. I have 1 liter in my hand, I don't know if it's enough.
08.05.2020 15:47 # 19
metin
[QUOTE = koliva] Sorry about the text, I really looked wrong.
No bro, what a flaw, for a moment I started to think that the automatic gears steering oil is different (:
Just as you said you changed it, I can change it. I had read articles like it is not easy to change if it makes weather in some places.
08.05.2020 15:47 # 20
EmRe26
The steering fluid or the like can all notice tire pressures. Watch out for him too.
Page : / 2
