why the maintained vehicle pulls left or right
08.05.2020 17:35 # 1
ismailkaya
the rod and the balance were adjusted and the steering wheel still feels crooked to my right and to the right
08.05.2020 17:35 # 2
Bugra
He did not manage to adjust the rod. take it again or show it to another master. the bidet may be a pull caused by the road. Pay attention, too. but I think the steering wheel is crooked is due to the master adjusting the rod.
08.05.2020 17:35 # 3
MagicPerformance
By the way, things are so surprising that the vehicles that came in were sometimes surprised that the last week of a vehicle had put the z-rod upside down.
08.05.2020 17:35 # 4
Serkan
My tires can also be made, teacher, some tires may have small production errors, I had zero tire on which side the vehicle was pulling in that direction
08.05.2020 17:35 # 5
emre_akdag
have the front tool checked again ..
08.05.2020 17:35 # 6
outlaw
Check tire air ...
08.05.2020 17:35 # 7
Aziz
so was my 306, although we did 3 times rot adjustment it did not improve. Go to the authorized service, it does not fit my device, said the car, we went to the backside, we stuttered the rotcu, we said, we could not stand 2 days later, I went to the authorized service and it improved. swearing at the bride: D
Go to the authorized service and try your luck there :)
08.05.2020 17:35 # 8
byx
[QUOTE = Serkan] My tires can also be made, my tires, some tires may have minor production errors, I had zero tires on which side the vehicle was pulling in that direction [/ QUOTE]
+1
08.05.2020 17:35 # 9
samet206
There may be bumps on the rims or defects on the tires. There was a bump on the front rim of the vehicle. We did not fix any problems.
08.05.2020 17:35 # 10
AydinBeyol
I think take it to the place where you made the rod adjustment. there is probably a problem with the tires.
08.05.2020 17:35 # 11
EErgul
tire weather may not be equal.
08.05.2020 17:35 # 12
It seems to me like a tire. The best way to understand this is to change the front tires from right to left. If the towing direction of the vehicle passes from right to left, it is one of the tires.
08.05.2020 17:35 # 13
cocomo
I agree with my teacher tire group.
my car is 2005 model, tires on 2004 model.
the right-left tires are so pert that the car is surprised where it will pull, trying to go straight last.
If the vehicle that is just out of the tie rod balance is still pulling, there is a problem with either the rim or the tires.
You are saying that both maintenance was new. vehicle performance has increased, maybe after maintenance, and you may realize that those tires are actually not able to meet the power of the vehicle. you may not have noticed if the vehicle is going without performance when it is neglected ...
The man who opens a rot balancer shop for one specialty does not remove the vehicle without proper rot balancing. it must be a very very very rotten business ..
08.05.2020 17:35 # 14
Bugra
[QUOTE = laedri] It looks like a tire to me too. The best way to understand this is to change the front tires from right to left.
+1
08.05.2020 17:35 # 15
Aziz
[QUOTE = bugrature] [QUOTE = laedri] It looks like a tire to me too. The best way to understand this is to change the front tires from right to left.
+1
+206 Clap
