Why the headlight stays on when the ignition is off
08.05.2020 18:54 # 1
baybaba
The weather got cold, the fog started, it is necessary to turn on the headlights during the day, I want to learn, a vehicle that knocks when the door is left open , allows the radio to steal for half an hour so that the battery does not run out when the ignition is closed , why I don't know how the other Peugeot vehicles do not switch off , but my 2007 model Partner This is the case, I had forgotten the headlights on and off last winter, when I arrived at 10 o'clock at night, the battery was exhausted, I could not find a car or something disgrace, I left the headlights on today, whatever came to my mind, I went back and turned it off, can anything be done to turn off the headlights when the ignition is turned off ?
08.05.2020 18:54 # 2
67okan
If there is, let's know ...
08.05.2020 18:54 # 3
Barut
I had the 2000 model 206, sometimes when I turned off the ignition, I sometimes forgot the headlights on after the disgrace. When I turn off the 206 2006 model contact in my current vehicle, the headlights go out, I think all of the models under 2003 have this problem, in 2003 and later peugeot models, the brain, etc. have changed, they have found a solution to this problem.
I saw a new 2007 model in your vehicle. My vehicle has a headlight sensor, so maybe it may be off automatically. Red dream 2014-11-29 01:05:50
08.05.2020 18:54 # 4
baybaba
Can the headlight sensor be retrofitted?
08.05.2020 18:54 # 5
denizci33
206 2008 model :)
08.05.2020 18:54 # 6
Efe-Pojo
He should have given a warning, didn't he?
08.05.2020 18:54 # 7
baybaba
There are no warnings, no matter how you will hear, you usually forget that the headlight is on (during the day) and close the car, it is not possible to understand how the peugeot engineers who cut the current in half an hour, do not turn off the headlight. Angry
08.05.2020 18:54 # 8
Efe-Pojo
No, leaving the headlight on and turning the ignition off, it sounds pretty hard to hear. but I don't know if it is not in the partner, after a certain period of time I know in passenger models, when the headlights stay on, it switches to econoomy mode and terminates anything that draws electricity.
08.05.2020 18:54 # 9
206cc57
My car is a 206 cc 2004 model, if I leave the headlights or parks open, it will beep and beep, if I get off without hearing it, the diseased signal handles made by peugeot engineers (chronic defective; you give a signal, the fog goes off, you press the horn, the headlight lights up, the headlights will light up, the horn will not work, if you wear a new one, 500 TL) the malfunctioning signal arm is activated for me, and automatically extinguishes.
