Why the engine auto diagnostic indicator lamp lights
08.05.2020 17:11 # 1
offchu
& Nbsp; Hello friends, I am a peugeot 206+ user (from April 2012), for 2 days the vehicle's engine auto diagnostic indicator lamp is steady, the car is quarter in the lpg li tank + gasoline available (taken 4 days ago).
& nbsp; I had a tremor and stop problem at idle after connecting the LPG in the past days, the problem was solved by installing the current software, cleaning the throat butterfly and adjusting the LPG path, but the vehicle is trembling and stopping at the idle for the last 1 week sometimes. it works smoothly, if I give an example, I officially cleared the ice from the car this early morning, the carburetor water was quite cold, so the car did not shake or stopped, for the last 2 days
My engine auto diagnostic indicator lamp is on when I clean the car, I saw something like water exhaust from the exhaust, I wanted to consult you because it is related to this, I would be glad if you do not withhold your information. Good forum for everyone. offchu 2012-12-09 11:48:54
08.05.2020 17:11 # 2
mesutay20
My teacher now I have the same problem. I will be glad if it will help .. (2002 307 1.6 16v xt premium)
08.05.2020 17:11 # 3
___KxL___
Engine diagnostic failure usually occurs with fuel related problems. If the vehicle throws raw gasoline from the exhaust, there is no burning. First of all, the gas adjustment of the vehicle should be done well. The flickering and stopping at idling can be from the gas adjustment or the ignition system & nbsp;. In my opinion, first make a nice gas setting. throat butterfly cleared already seems to be the only problem.
08.05.2020 17:11 # 4
offchu
Hopefully, as you said, the problem is only for the reasons you counted. If I am available tomorrow, I hope that I will stop by the service and it will be improved.
08.05.2020 17:11 # 5
Serkan
[QUOTE = offchu] Hopefully, as you said, the problem is only because of the reasons you counted. [/ QUOTE]
I remember if you did not have 3 lines of screens, if I have any warning data on the screen?
08.05.2020 17:11 # 6
offchu
[QUOTE = Serco05] [QUOTE = offchu] As you said, I hope the problem will be solved if I am available tomorrow because of the reasons you just counted. [/ QUOTE]
No yet, my teacher.
08.05.2020 17:11 # 7
Alicilik
Let's have a look at it and let's plug it into the OBD scanner and see what error it is there. Have you ever been to the Pejo service?
08.05.2020 17:11 # 8
offchu
[QUOTE = Receiving] Let's talk about it sometime, let's plug it into the OBD scanner and see what error it is there. Have you ever been to the Pejo service?
I see the message of my teacher Ali, I can not enter the forum constantly, sorry for the late reply, I took the vehicle to the oxygen sensor sensor error, we changed it for now. no problem let's see thank you for your attention. By the way, I could not get the water screen somehow, I went to Konya but I did not have the opportunity :(
08.05.2020 17:11 # 9
ALLEX
& nbsp; & nbsp; Hello everyone, everyone ...
I gave my car, entrusted to a friend. & Nbsp; When I brought it two yesterday, I realized that it bought diesel.
I always buy from Shell, but I didn't want to ask where my friend got it.
this morning I got into my car, turned the ignition, started, but did not work. He tried to pressure one more time. I have not been in doubt until here.
I went to some places until noon, there was no problem with stop start or something.
About 1 hour ago, I left the car in the shopping mall and went to the shopping mall. Surpriiiiiz ...
"Angry"
the starter is pressing again, but it is not working. The engine malfunction lamp is on and does not go out. div>
what would you recommend to friends with knowledge about the subject ..
