Why Tachometer Flickers?
08.05.2020 18:36 # 1
serkomser
Greetings,
I noticed a new problem in my vehicle, maybe I did not know that it had increased before, but the problem is this;
I see that the tachometer vibrates when I deliver gas up to 3000 rpm while the vehicle is stationary.
In standby mode, the vehicle is shaking (Sometimes too much, sometimes not)
Sometimes it kicks and shocks (shake back and forth) 2-3 times while the car is hot on the hill.
Spark Plug-Coil-Fuel Pump. Sturdy
What could be the problem? Can we evaluate?
08.05.2020 18:36 # 2
okaNStarss
have throat throttle, relay and oxygen sensors checked, but the throat butterfly was similar to the father's toyo, the tachometer fluctuated.
08.05.2020 18:36 # 3
serkomser
The problem is solved with spark plug replacement.
08.05.2020 18:36 # 4
madblueblacksea
[QUOTE = sarcomser] Problem solved with spark plug replacement. [/ QUOTE]
The spark plugs were intact Party
