why steering wheel
08.05.2020 17:56 # 1
kasirga16
Hello friends, is the steering hum in the 307s a chronic problem? what is the solution . Is this sound that is heavily heard especially at low speeds and rotators a sign of malfunction? And what is the reason why the lights are faint in these turns?
respects
08.05.2020 17:56 # 2
qqyyxx
what is the model of the vehicle. I heard the humming event from a few users. But the weakening of the lights is an electrical event, it is very likely to be related to the steering pump.
08.05.2020 17:56 # 3
ondercan
when you break the steering wheel, the current draws too much, because the steering pump loads, the lights become weaker, this is normal.
Good luck with
08.05.2020 17:56 # 4
kasirga16
307 sw vehicle, yes, when the steering wheel is broken, the sound becomes more intense, I am glad it is an ordinary situation
08.05.2020 17:56 # 5
kasirga16
thanks guys for sharing your experiences
08.05.2020 17:56 # 6
qqyyxx
[QUOTE = onurazgin] The usual situation solution is 90% of the current hum. The steering pump of the direksiton pump is not functioning worn. It is not important, but if you obsessed, you can remove the bumper and change its gasket. sound cut 90%. the weakening of the lights is both from the battery and from the load as the friend mentioned. have your battery checked, it may be overdue. or how many minutes does it enter the economy mode? If half an hour is fatal, your battery is healthy. if it goes in 5-10 minutes, the battery is dead. [/ QUOTE]
where is this gasket, can you give some information?
08.05.2020 17:56 # 7
lamazibici06
Since the steering pump is electric in the 307s, there may be sound due to failure due to power loss.
