why not the cruise control?
08.05.2020 14:52 # 1
Hello,
I have a 2004 model 307 auto. I wanted to have a cruise control installed on my vehicle. the cruise control lever came and sat down. We came to the introduction section from the computer, there were 5 different options in the menu.
type A / type B / type 2 with cruise control without speed limiter / with speed limiter / without cruise control
We tried the above in order :( but it did not. It is only in type 2 speed stabilization with no speed limiter option, Cc --- writings are displayed in the upper line OFF in the top line but it is not active. I have tried all the options many times.
We tried the 2003 model with a 307 manual gear. however, there are two choices in his mesure that there is only speed stabilization. I chose var and tried. no text appears on the information screen, but the arm is working and used as a hand gas.
my main question is, isn't the arm we already have suitable for my vehicle? I looked at peugeot's site, there is a third option of the arm on off button, which actively describes the cc post: limit. I wonder if the arm is wrong. Friends who have installed or used automatic stabilization of automatic gear 307, I would appreciate if friends with knowledge on the subject can help. Thanks.
08.05.2020 14:52 # 2
shamed
First of all, introduce yourself to our members.
08.05.2020 14:52 # 3
[QUOTE = shamed] First of all, introduce yourself to our members get to know ... [/ QUOTE]
ok brother, that's not a problem, we can handle it, but is there anybody to answer my question?
08.05.2020 14:52 # 4
individual
Hi
First, some 307s do not have speed stabilization.
this is because of the gas wire. The speed stabilization will be applied in 307 and there is no gas wire, that is, the drive by wire system must be present.
In the 2003 models, the gas wire is clearly visible above the left headlamp in some 307s.
Gas wire application was abandoned in 2004 and above models.
Let's come to your question.
I had the same problem years ago. I wasn't alone at the pc.
We set off after attaching the arm. Cc --- appeared on km counter.
ok, we said it was a vehicle, but unfortunately the cruise control didn't work.
then the friend chose another parameter. This time, cruise control worked, but Cc was not displayed on the km counter.
The Cc statement does not appear in the old cases already in the km counter. is coming out in new cases.
I don't think that we will see the word CC On in the km counter.
It will work in a way.
Gülme
08.05.2020 14:52 # 5
xMEGANx
individual brother I think your name is Engindi correct if I am wrong, is it okay if I put a cruise control on my vehicle? and what is the total cost? New chassis 307 2007 model Comfort
08.05.2020 14:52 # 6
individual
Hello my name is Ergin
speed stabilization for every 307 without a gas wire.
even the vanity case 307 is in speed limitation.
I think the arm prices are between 150-200.
You give workmanship at 20 to 50.
If there is a familiar service, the price drops even more
08.05.2020 14:52 # 7
xMEGANx
[QUOTE = individual] hello my name is adult
Well, Ergin, thank you. Bid is that you haven't posted an answer for the monitor for 2 days. I look at it.) Bid if you clarify it :)
08.05.2020 14:52 # 8
individual
[QUOTE = xMEGANx] [QUOTE = individual] hello my name is adult
Well, Ergin, thank you. Bid is that you haven't posted an answer for the monitor for 2 days. I look at it.) Bid if you clarify it:)
I did not see, what did you write?
08.05.2020 14:52 # 9
xMEGANx
I couldn't find it now. You know, you had a topic or I asked you about fuel, I asked how I bought the LCD screen and the 5 Cd player. I would be very happy if you help me think too.
08.05.2020 14:52 # 10
individual
Don't look at my flaw, he's gone.
I answered you. If you couldn't find the related topic here
08.05.2020 14:52 # 11
xMEGANx
Thank you bro
08.05.2020 14:52 # 12
[QUOTE = individual] hi
Gülme
suitable for vehicle cruise control, ie no throttle cable
If I ask exactly which parameter was :) I would have asked a lot.
There is also a menu difference between automatic and manual, so your friend only has no parameters in 307. Actually, I am already willing to have a No and No menu.
I tried all the menus one by one, but it didn't work anyway :( is there something we have to do or do something missing?
I will declare from his companion :(
speed fixing arm for sale
08.05.2020 14:52 # 13
10ur1
So how would this speed stabilization be 206?
08.05.2020 14:52 # 14
serkan24577
I was just wondering if I get 206
08.05.2020 14:52 # 15
individual
the cover
the speed stabilizer arm you bought?
or is it both cruise control and speed limiter?
08.05.2020 14:52 # 16
[QUOTE = individual] closure
Üstadım,
I currently have a cruise control but I couldn't run it :(
Is it the arm that is suitable for the vehicle, both fixing and limiting? I'm looking for an answer to this question.
As I said above, the vehicle is a 2004 1.6 automatic gearbox. I could not operate the unlimited one way :( I mean I think the limited arm is suitable for our vehicle, so is it not working?
Friends who have automatic gearshift and cruise control are not bad.
I am looking at the 2004 model from http://public.servicebox.peugeot.com/ddb/code/index_en.htm page 135. On page 135, the two-stage on-off button arm and its functions are explained. In the narratives here, there is no text coming on the screen and it tells the functions of fixing. As a matter of fact, I tried it in my friend's 2003 1.6 manual gear car, it works even though there is no text on the screen.
136-137-138 at the same place. On the pages, a model fixing arm with Cc active on the screen but with a limiting option other than on off on the arm is explained. With the articles that will come to the screen.
So this is the issue I'm wondering. I wonder if the arm with the option to limit my car is suitable?
Note: I have 5 connections on the socket part of the arm that does not have a limiting option that works as on off, but there are 7 conductors in the corresponding place. I just looked at the tape arm 7 to 7 because I was wondering, but unfortunately I didn't think how many conductors in my friend's vehicle have to check it in the same place :(
Note: I apologize for spelling mistakes, expression errors, and composition flaws. I am improvising as I can think of it.
08.05.2020 14:52 # 17
individual
greetings
your vehicle needs a speed-free arm.
rather, the speed limiting function does not work. For this, the vehicle must be CAN BUS.
Since your vehicle is VAN BUS, only the cruise control arm is sufficient.
it is natural that you cannot operate. a few friends called me over the phone and asked.
they were not able to operate while attaching speed stabilization to the old cash register vehicle.
they did not call later, it was probably stuck and working.
if your arm may be broken or if you don't get it wrong, change the service.
van bus- old body
can bus- new chassis by the way
08.05.2020 14:52 # 18
thank you for your interest.
According to what you say, the arm we have is only the arm that is fixing, not speed limiting, which is suitable for the vehicle. At least we have guaranteed this :) So we have another problem :( I will consider your last suggestion. Thank you.
NOTE: I will struggle until I work hard Gülme I hope it won't be long. If we can run it, I will inform you again. Good forums.
08.05.2020 14:52 # 19
only_younus
Can I find out how many lira you get from the cover cruise control arm?
08.05.2020 14:52 # 20
I think my piece brought me from a service from Ankara. 156 + 4 lira shipping cost I got 160 lira :) it just stands :)
we did a few more trials today but it didn't work again Wall
the cover 2010-08-20 20:03:00
Page : / 2
