why not go
08.05.2020 16:13 # 1
efsanemurat
slm friends I have a question for you, my vehicle has been in the 1st and 2nd gear for the day, until 2000 revolutions in the car as if somebody is holding the car then suddenly the car is raising it is not always but doing the bidet split up the car shouting
08.05.2020 16:13 # 2
catalyst failure likely
08.05.2020 16:13 # 3
efsanemurat
what is this catalyst where is your car. How to fix this failure
08.05.2020 16:13 # 4
mimitt
The catalyst is part of the vehicle's exhaust system, but in vehicles where this system is available, the system-related warning system is also available, you can connect the vehicle to the computer to find out if there is a problem with this system. In order to avoid this, we need to have a catalyst installed so we can also treat the environment with respect. In this way, you can find catalysts certified in the industry starting from 250 TL. The original parts are usually much more expensive as they are sold with the manifold part. & nbsp; is continuous. So it is not an instant situation.
does not feel like a direct catalyst to me, is there a lpg in the vehicle?
08.05.2020 16:13 # 5
efsanemurat
the vehicle is new in diesel and maintenance but the problem started after maintenance
08.05.2020 16:13 # 6
There is a plastic pipe coming from the back of the air filter box to the front left headlight, it may not have been seated. The car then came to me.
08.05.2020 16:13 # 7
mimitt
It would be much better if a master saw it, assuming the vehicle was a diesel, & nbsp; was the westagate of the turbo that came to my mind second.
08.05.2020 16:13 # 8
muzaffer
I also have the pipe to the air filter, I believe that the air filter is likely to have been displaced there, so I've lived it, the car is falling out of traction.
08.05.2020 16:13 # 9
mimitt
Oh yeah, can it be a turbo suction hose :)
08.05.2020 16:13 # 10
muzaffer
[QUOTE = mimitt] uh yeah maybe it could be a turbo suction hose:) [/ QUOTE]
Just like my mimit first came to my mind, it was probably out of the bidet maintenance, so the vehicle is not able to get the air completely, it is suffocating. "Laugh"
