Why is the information screen not appearing?
08.05.2020 16:01 # 1
tugay307
slm friends arcım 2004 model 307 hdi the screen in the middle is not visible during the day, it becomes clear at night but still there is a little bit of what should I do
08.05.2020 16:01 # 2
hit the top of it :))) daytime running lights disappear closely :)))
08.05.2020 16:01 # 3
metin
The brigade has never investigated (:
More precisely, it is a chronic malfunction of those screens. When it gets too hot in the sun, the screen starts to fade in the evening because it is cool and returns to its former state. Göz Kırpma
08.05.2020 16:01 # 4
Saleeh
The problem can be solved by buying a new one :) There are friends selling 3 lines of screens in the forum. if you want a search.
08.05.2020 16:01 # 5
In order for LCD screens to function properly, the temperature must be between certain nerves. Liquid crystal molecules that are parallel to each other at normal temperatures lose their parallelism as the temperature increases and become mixed. This means that the screen loses its function. Generally, with the decrease of the temperature, that is, the molecules become parallel to each other, however, when exposed to this temperature for a long time, permanent defects may occur. Therefore, leaving the vehicle under the sun damage the screen first.
The backlighting lamps, which are only in contact with the top, are temporarily contacted. But you will see that the lamps will be cut after hitting two ends.
Go to the way to replace the lamps. If the problem is not from the lamps, it will be necessary to replace the screen.
Koliva 2011-08-20 20:05:19
08.05.2020 16:01 # 6
this is happening with me I think the fate of the 307s
08.05.2020 16:01 # 7
metin
[QUOTE = Saleeh] The problem can be solved by buying a new one :) There are friends selling 3 lines of screens in the forum. if you want a search. [/ QUOTE]
the new one changes the same maximum temperature, so if the old screen in your hand starts to be wiped at 30 degrees, the new will start to wipe at 40 degrees but I think it will be so much.
I don't remember which model 206 is xs or xt, but they said that the screen in that model did not cause any trouble.
08.05.2020 16:01 # 8
You say right, I think we shouldn't get hands on, no problem
08.05.2020 16:01 # 9
Thumbs Up
08.05.2020 16:01 # 10
metin
[QUOTE = efe_senkader] you say right, I think we shouldn't get hands on, no problem [/ QUOTE]
yes senol brother. I also do not know how effective there are such solution methods.
The first is to place it between the screen. Of course, it does not end with the placement that the fan should draw the cold air to cool.
Another solution is by blowing the air conditioner towards the windshield and decreasing the temperature of the screen there, and you can restore the screen.
08.05.2020 16:01 # 11
[QUOTE = text] [QUOTE = Saleeh] the problem can be solved by buying a new one :) There are friends selling 3 lines of screens in the forum. if you want a search. [/ QUOTE]
It has been a few months of change and I would like to report my satisfaction. I think 206 RC has a screen, 3 lines, or even the trip computer feature is turned on. Unfortunately, this is a problem that is found in some 307s and is skipped chronically, but I tried it in the summer, although the new screen I bought did not show the slightest signs of paleness, although it was under the sun.
the mustafa_usl 2011-08-21 02:55:31
08.05.2020 16:01 # 12
[QUOTE = mustafa_usl of]
Nevertheless, do not leave it under too much sun. I see that there are not many people who raise this problem in the British or Belgian forum. Why is that? Because there is no sun Kahkaha
Koliva 2011-08-21 08:30:43
08.05.2020 16:01 # 13
metin
[QUOTE = koliva] [QUOTE = mustafa_uslu]
koliva was good Kahkaha
08.05.2020 16:01 # 14
Ozgur
Mustafa brother, if you want to wait under the sun for days, your screen will not fade again.
because you have 206 screens. Those who have 307 screen should not wait. :)
08.05.2020 16:01 # 15
Saleeh
[QUOTE = Free] Mustafa brother, wait for days under the sun if you want, your screen will not fade.
2 lines was not enough for us Sırıtma
08.05.2020 16:01 # 16
g-demir
[QUOTE = efe_senkader] this is happening with me I think the fate of the 307s
The fate of all 307s whose windscreen is not covered with film and is exposed to the sun. change solution screen
08.05.2020 16:01 # 17
metin
[QUOTE = g-iron] [QUOTE = efe_senkader] this is happening with me I think the fate of the 307s
changing the screen is not the solution (: the new one will do the same. nice will do it a bit later but it will do (:
08.05.2020 16:01 # 18
g-demir
you will protect the screen from the heat that you cannot. he also needs a lot of attention. So if we change the screen every two years now, it is 100 lira in two years, if we get on average 6 years 3 times from 100 lira ... Wall
08.05.2020 16:01 # 19
alisuat
teacher, you need to change your bulbs, there is a cost of 5 TL,
If there is light but the texts are not read, install 150 tlye 206 screen and there is no problem.
08.05.2020 16:01 # 20
metin
[QUOTE = alisuat] teacher, you need to replace your bulbs, there is 5 TL cost,
but all the 206 screens are not the same, there is a bite model. Wall
Page : / 2
