Why is the engine noise that changes to gas pressure?
08.05.2020 20:02 # 1
prdxy
Hello friends, I just bought my 206 1.6 xs car.
When the car over presses the gas and forces the engine, it sounds like there is an abarth exhaust.
Is it possible that the engine has been tampered with or what is the problem?
prdxy 2016-11-15 12:58:26
08.05.2020 20:02 # 2
CVT
Could there be an air filter
08.05.2020 20:02 # 3
monalos
Clutch can also be a problem, if the clutch does not perform properly, when the gas is released, the engine will be idle, it will cry out, the same will happen in me, the pad will change.
08.05.2020 20:02 # 4
aykutcerit34
It is useful to show the master, the engine may also be a problem. You need to have the hoses checked by the air filter.
08.05.2020 20:02 # 5
TugyyStyle
Most likely air filter after 5 thousand cycles
08.05.2020 20:02 # 6
monalos
[QUOTE = TugyyStyle] Most likely air filter after 5 thousand cycles [/ QUOTE]
You say the filter is dirty, it screams a lot, but it goes different
08.05.2020 20:02 # 7
ALLEX
The middle exhaust muffler or the manifold may have a cramped area.
It is not clear at low pressure, but the sound coming out from the point that will increase when the pressure increases at high speeds manifests itself.
I think you should look at the exhaust and then the air filter connections. ALLEX 2016-11-15 23:17:49
08.05.2020 20:02 # 8
dogan106
they may have fitted the vtec engine without a crash: D
08.05.2020 20:02 # 9
outlaw
[QUOTE = dogan106] they may have installed the vtec engine without a crash: D [/ QUOTE]
LOLLOLLOL 206 vuavvv with vtec engine
08.05.2020 20:02 # 10
ALLEX
[QUOTE = outlaw]
Can you be on V8? .
08.05.2020 20:02 # 11
prdxy
I think I will upload the photo played with the air filter tomorrow, friends.
08.05.2020 20:02 # 12
prdxy
V16 can also be 5000hp
08.05.2020 20:02 # 13
maximusti
teacher, you just bought the vehicle, no engine etc. The göstermedinm?
By the way, we forgot to say good luck :)
I maximus 2016-11-17 09:57:58
08.05.2020 20:02 # 14
prdxy
I showed the master in the industry played with air filter assembly. I bought the original parts from the man. Thanks everyone
