Why is 307 Peugeot car antifreeze missing in motion
25.02.2021 19:18 # 1
Selim1905
307 vehicle is in motion, the antifreeze is decreasing, why does it? I couldn't see the leak
01.03.2021 08:51 # 2
Teacher, there may be a few reasons. The biggest reason for the reduction in motion is because the water heats up, the pressure in the system increases and it can cause it to escape from somewhere. As for the places where there may be leakage. Spare water tank cap - Radiator - water hoses and heater core.
02.03.2021 12:17 # 3
Selim1905
We could not find anything visible, I will look at the heater core, but if there is a leak from there, the mats will be wet Du I do not understand, there is a small crack or something, I guess it gets hot and grows in motion.
02.03.2021 22:24 # 4
sozuak
If you are using orange antifreeze, you can check the connections in the dark with the money control lamp and you can detect the residuals in the flowing places with a phosphorescent glow.
Since the engine evaporates immediately when it is hot, it is difficult to detect by eye if the current is not much.
Heating heater and heater inlet pipes
Both ends of lpg regulator hoses, if any,
Cracked circulation pump cover
Cracks in the radiator.
Cracks in radiator hoses
04.03.2021 16:29 # 5
Selim1905
I use antifreeze, which is the most effective, I looked at the heater, there was no leak, I could not find the problem yet, I showed the problem to the master, the radiator was aired, he could not see the leak from the cover, he said it is from the junction, he said, they did check the junction elsewhere, as if the car was overheated with medication and the junction was also solid
05.03.2021 21:05 # 6
sozuak
Is the vehicle diesel or gasoline?
If there is LPG, look at the regulator connections, or take it from the bottom and look at the circulation where else.
10.03.2021 01:52 # 7
Selim1905
The vehicle can be LPG as you said with gasoline LPG.
