Why doesn't my vehicle work?
08.05.2020 19:25 # 1
emresensoy307
If my friends turn off the ignition after I have been doing 100 200 km for two days, I will not work again after about 1 hour. Could I have a clean antipaullation error in the coolant?
08.05.2020 19:25 # 2
sezar206
Get well, my brother is an interesting problem.
08.05.2020 19:25 # 3
emresensoy307
I actually supplemented with spark plugs, there was an intermediate clio in my father.
08.05.2020 19:25 # 4
talip206
Does it start or does it sound like teak and not starter?
08.05.2020 19:25 # 5
emresensoy307
mars basio kirkir do not get it
08.05.2020 19:25 # 6
talip206
Since the sensors are generally sensitive to heat, they can often cause trouble after warming up. there is probably a problem with the heat-temperature sensor. If it hadn't started, I would have called a starter but it was.
08.05.2020 19:25 # 7
emresensoy307
I get my car done on time, but when such problems arise, the morale of the person is deteriorating. This sendor is expensive ...
08.05.2020 19:25 # 8
emresensoy307
A current ....
08.05.2020 19:25 # 9
teacher, it was gasoline, right?
08.05.2020 19:25 # 10
emresensoy307
Yeah
08.05.2020 19:25 # 11
Have you ever connected the tool to a computer. it may be related to sensors. or one of the injector malfunctioned.
08.05.2020 19:25 # 12
talip206
[QUOTE = emresensoy307] I get my car done on time, but when such problems come out, the morale of the person is deteriorating. This sendor is expensive ... [/ QUOTE]
Honestly, whatever vehicle you buy, the parts wear out and deteriorate over time. Even the condition of the roads is known, even zero vehicles are malfunctioning. As I wrote above, it probably looks like sensor failure. When a good master solves it immediately
08.05.2020 19:25 # 13
emresensoy307
He did not work yesterday, I called the master in the morning, he came, he looked, he did not work when he wanted it.
08.05.2020 19:25 # 14
emresensoy307
guessing about the key
08.05.2020 19:25 # 15
If immo is not reading, sir, do you have a spare key. Try it with it.
08.05.2020 19:25 # 16
emresensoy307
Now I will try when I go home ...
08.05.2020 19:25 # 17
emresensoy307
Yes, Arkads found a problem. The engine fuse box was operated by making a master bridge, but for now, the air conditioner will be overloaded, so we will be able to handle a high price for now.
08.05.2020 19:25 # 18
baybaba
Get well soon, do you have a car? Smile
